July 11, 20197 yr Hello world, I'm running Enpass 6.1.1 on mac OS X High Sierra 10.13.0 and Firefox 68.0 The Enpass extension is unable to find an entry corresponding to the current website, but when I do a manual search it appears. It's a frustrating and time-consuming issue. Is there an obvious setting I should be using to avoid it? Here's 2 screenshots of my experience.
July 12, 20197 yr Hi All, Can you please check and let me know have you enabled the Match URL hostname under Enpass settings > Browser section? If yes, then retry by disabling it as once this option is enabled, Enpass extension will only show you the list of items having the exact matching URL. '
July 12, 20197 yr Author Hi Vikram, Thank you for reaching out. The option is not checked under browser settings. I recently imported passwords from Dashlane, so maybe that could be causing the issue. Here's more details about the URL stored in Enpass.
July 13, 20197 yr On 7/12/2019 at 1:23 PM, Vikram Dabas said: Hi All, Can you please check and let me know have you enabled the Match URL hostname under Enpass settings > Browser section? If yes, then retry by disabling it as once this option is enabled, Enpass extension will only show you the list of items having the exact matching URL. ' Sorry but there is nothing to check. I have the same problem and today I realized the Chrome add on doesn't work at all on my Mac.
July 14, 20197 yr From what I can see on your screenshot @Twizzlers, your “Domain” field’s type is not URL.
July 14, 20197 yr 8 hours ago, xarekate said: From what I can see on your screenshot @Twizzlers, your “Domain” field’s type is not URL. Hi. Did you read my post? I have the same problems. And in Chrome there is no function!
July 14, 20197 yr @Friedi Yes, but I cannot say anything about Chrome as I'm not using it. But @Twizzlers has probably the problem that his “Domain” field’s type is not URL (that's what I see from his screenshot), but there might also be another issue, I don't know. He should just check it out. Finally I can tell you, I have no issues with archive.org or any other website, when all needed fields are setup correctly.
July 15, 20197 yr Hi @Twizzlers When a webpage is opened, Enpass extension shows the relevant items based on the URL (field type is set as URL) saved in items. So please make your Domain field is set as URL. You can change it via Open the Archive item > Edit > click the Domain field > Set the Field Type as URL > Save it. Now retry and let me know if you still face any problem
July 15, 20197 yr Hi @Friedi I need some more information so that our team can investigate the issue. Please share the: Enpass version. Device and OS version. Chrome and Enpass extension version. Does the issue occur only with the Chrome extension?
July 15, 20197 yr Mozilla Firefox works fine. SRWare Iron (Chrome fork) works fine. No issues so far....
July 17, 20197 yr Author @Vikram Dabas Tried it, it works. Thank you ! Is there a way to change domain type for all items?
