Scanned QR code (keyfile) not saved on iPad
I would need help resolving this issue on my iPad (Iphone works).
Edit: Re-installing the app might resolve the issue. It did for me at least.
The scanned QR code (keyfile) is not saved on my iPad. I am required to select the keyfile manually (the Enpass login screen shows a second keyfile field) every time I am logging in to Enpass.
Initially I created a new password including a keyfile locally on my laptop.
On my iPhone I changed the Enpass password and scanned the QR code to get the keyfile on the Iphone's keychain as explained in the user's manual. As expected I can use the iPhone's Touch ID to login to Enpass.
But doing the same steps on my iPad I am always requested to enter the Enpass password and select the keyfile manually before I can log in.
How can I resolve this so I get the same behaviour on my iPad?
Any help much appreciated
/Torbjörn
Edited by Torbjörn
Update resoltion
Hey @Torbjörn,
Can you please let me know are you running the Jailbreak device so that I can help you better.
Thanks!
The iPad and the iPhone are running  IOS 12.3.1 (without any jailbreaking)
regards
Torbjörn
Hi again
I re-installed  Enpass on the iPad and that resolved the issue.
best regards
Torbjrn
