August 5, 20197 yr Hey Together, i use Nextcloud with Webdav for my Enpass Vault for a long time now. Now i get the Sync Error with Error Code 907018. In the Internet there is absolut no Hint what 907018 means. Reconnect the Webdav doesn´t change anything. Have somebody an explanation what this code means? Thx
August 6, 20197 yr Hi @McD_HRTS Sorry for the inconvenience caused to you. It would be a great help if you can share the demo account of your WebDAV via PM so that we can check where the problem could be. Thanks for your co-operation.
August 8, 20197 yr Author Hi @Pratyush Sharma, the Error is since today gone (absolut no idea why, no change in Nextcloud or Enpass). I will check out the next few days and give you feedback. thx
April 11, 20206 yr Hi, from today I’ve got the same problem. I reinstalled my Nextcloud and updated it to 18.0.3, since now Enpass can’t sync. The error is 907018 as well. What can I do?
April 14, 20206 yr Hi @heldausberlin, Sorry for the inconvenience caused to you. It would be a great help if you can share the demo account of your WebDAV on support@enpass.io, so that we can investigate where the problem could be.
