Posted
Let us say, I am at a page ready to fill user/pass, then I press in EDGE the Enpass icon, as soon as I press it, it will switch to a different tab, randomly, sometimes it does it sometimes it doesn't, but it is very annoying, because then you have to select back the tab you wanted to fill in the credentials with Enpass.
Guest Akash Vyas
Posted
Hey @brosenz
This is a known issue and the tech team is currently looking into it.
Cheers!
  • 2 weeks later...
Posted
On ‎1‎/‎10‎/‎2018 at 6:03 AM, Akash Vyas said:
Hey @brosenz
Cheers!
With the latest version of Enpass, now it will jump to the far left section (tabs you have set aside) of EDGE.
Posted
At this point in time, between Enpass jumping into other tabs, the application crash and the connection error of the extension, Enpass it is pretty much unusable, I have so many issues every time I try to use it
