JeffB Posted February 17, 2018 Report Posted February 17, 2018 Wife using Enpass on Surface Book with 27" external monitor connected through Surface Dock. When opening MS Edge, the Enpass Extension will pop up UNDER the browser window. And then she cannot find the dialog, so she thinks it isn't working. If she turns off Maximize, the browser window covers only about half the screen, and then the Enpass dialog appears "appropriately" next to the browser window. She can then double click the entry to sign in and then maximize the window again. It works but is a nuisance. Maybe you can find a solution in your schedule, or maybe there is a better work around. Thx, Lovin' Enpass.
