Error 120
Hy, Today i started with Enpass on 1 Windows PC, 1 IPAD, 1 Iphone. I Sync via Webdav with my QNAP NAS. Sync is working without Problems on all Devices.
But every 60 Seconds i get an Error 120. (See Attachment). I try to sync with varius Webdav Servers. Sync ist always working, but the Message still appears.
Regards
Achim
Hi @Achim,
Thanks for reporting this issue and I apologize for the inconvenience. Please provide some more details so that we can investigate where the problem could be.
  • On which devices (all of them, along with OS version) are you using Enpass?
  • Are you facing this problem in the specific device or in all devices?
It would be really helpful if you can share a demo account of your WebDAV to us at support@enpass.io or in a personal message to me so that we can investigate where the problem could be and try to fix asap.
Hy, i use iPhone SE with IOS 10.2.1 and iPad Pro with IOS 10.2.1.
Enpass Versions are the newest availables.
All Devices have this Problem.
I tryed with different Webdav Connections. QNAP-NAS (Local LAN and over Internet) , Western Digital-NAS (Local LAN and over Internet) and Webdavaccount (Provider: Hosteurope)
Hi @Achim,
Thanks for your reply.
If possible, can you please create and share a demo account of your WebDAV to us at support@enpass.io or in a personal message to me so that we can investigate where the problem could be, and try to fix asap.
Thanks for your co-operation!
Hy and thanks for your reply.
I switched to another Password Manager yesterday. So i need no more help.
Thanks anyway.
Achim
