January 6, 20206 yr Enpass on Android does not open up when I have no internet connection available. Before the big update this was not the case. Please report this as a bug. Thanks
January 9, 20206 yr Hey @CT94, Welcome to the forums. It's strange to read as Enpass doesn't require an active network connectivity while opening or logging in. On 1/6/2020 at 2:08 PM, CT94 said: Enpass on Android does not open up when I have no internet connection available Could you please share the Android version, the Enpass version and the device name? Also, do you face any error or an issue while opening Enpass without an active internet connection? Thanks.
January 27, 20206 yr I am seeing this as well. When I don't have an internet connection, Enpass accepts my credentials and then just displays the blue screen with the padlock. Restarting the app doesn't help, the problem reproduces again. Works normally once I have an internet connection. Enpass 6.3.4.298 Android 7.0 Samsung S6 Edge+
January 29, 20206 yr Hey @MichaelS, Thanks for sharing the details; we've cascaded the same for testing. Could you also please confirm whether you were using any cloud to sync the Enpass data before facing this issue? And, does Enpass demonstrate this behaviour with mobile cellular data or WiFi or both?
February 5, 20206 yr Hi, just to say that I'm having the same problem. To me it happens without wifi (not specifically tested with wifi), when the cellular signal is low or missing. These are my phone specs: - Enpass: 6.3.4.298 - Android: 9 - Device: Oneplus 3T - Cloud sync: Google Drive Hope this helps, it's a very serious problem for me. Thanks.
February 6, 20206 yr Hi @poluz @MichaelS @CT94, Sorry for the trouble you are going through. Our Dev team is looking into this issue, and we will update you once we hear from them. Thanks!
