Adding a shared item
I have followed the instructions in Share to share a login from my mobile app to my desktop iteration of Enpass, which is on Linux. I used a private cloud to share the login (using PSK), and got an `.enpasscard.txt` file on the other side. It is unclear to me how to follow instruction in Adding a shared item to now import the password on my desktop. What am I missing?
Hey @Jonatan,
Thanks for posting your concern on the forums!
The extension of file containing item should ideally be `.enpasscard` and not a .txt. You'll have to check how .txt suffix appends at the end. Once you have a ".enpasscard" file on your system, you can open the same using installed Enpass application. You could also share items (in .enpasscard format) via email protected with a PSK.
Let us know if this helps.
Thanks.
@Kashish, thank you. Yes, changing the extension worked.
The file was generated as is (with a `.txt` extension) when I used "Share" from my mobile phone (Samsung GS9+ running Android 9) using "ownCloud" cloud storage as a medium.
Anyway, thanks again.
Thanks for the confirmation. You could reply if there's anything else, you need help with!
