March 5, 20206 yr I have installed Enpass on two computers and it has been working for about three months now, however, it quit working on one of my desktops. I have uninstalled it on the computer that it failed on, and then re-installed it, with no luck. What do I need to do to get it working again?? Both machines are ASUS Deluxe II MB: MX-Linux 18.3 Continuum: Enpass 6.4.0.631. UPDATE: Enpass has now stopped working on BOTH computers!!! Edited March 5, 20206 yr by woodyb12
March 6, 20206 yr Sounds kind of like a problem I am having presently (thread here). I had to downgrade mine as a temporary work-around. When you try to execute Enpass in a terminal, what output does it give you?
March 6, 20206 yr Hi @woodyb12 and @SR68503 Sorry for all the trouble you are going through. I have noted down this issue and notified the concerned team to look into it. Thanks for your cooperation.
March 15, 20206 yr Ook bij mij met Linux Mint werkt Enpass niet meer. Jammer, ik gebruik het al een tijd en nu sta ik mooi te kijken.
March 18, 20206 yr Hi @woodyb12 & @Mathijs, Sorry for the trouble you are going through. Please let us know on which device and OS version you are using Enpass.
March 18, 20206 yr Author I am using two Desktop Computers; both are ASUS X99 Deluxe II, as well as two different laptops; a Dell Latitude e6500 and a Dell Inspiron (don't know the model). They are all running MX-Linux 18.3 Continuum. Currently Enpass 6.4.0-631 will sometimes act like it is going to start, but then just dissappears; this occurs on every machine I have installed it on! (All of the Above.) The extensions do not work either. When I downgrade to version 6.0.0.-149, it works again. I can't figure it out!
September 10, 20206 yr Hi @SR68503 & @woodyb12, We've released an updated version of Enpass for Linux platform in which we have fixed this issue. Could you please update the app to the latest version and let us know if you're still encountering the same issue with the app? Thanks for the co-operation.
September 11, 20206 yr Hey @Juliano Thanks for notifying us and we are glad to know that the issue has been resolved. Thanks for the co-operation.
