March 14, 20206 yr Hi Enpass team, I have been experiencing very persistent crashes on my Ubuntu 19.10 laptops (stock Ubuntu version with latest updates), including a brand new build installed from scratch quite recently. Typically crashes occur when I try to invoke Enpass from Firefox to fill out some login details using the shortcut key; however since upgrading to 6.4.0.631, they've also started to occur without any interaction: I just had it SEGV on me while my session was locked (an Apport notification popped up on the lock screen). I think those crashes started occurring with version 6.2 or thereabout. They were definitely already a feature with 6.3. I've been an avid Linux Enpass user since June 2016 and it had been a pretty solid experience until then. I am submitting the crash report feedback when prompted by your integrated reporter - must have done so at least 15 times over the past 2 months - but not the Apport ones for obvious reasons (core dumps). Today's - while my laptop was locked - has this: SegvAnalysis: Segfault happened at: 0x536329: mov 0x48(%rbp),%r8 PC (0x00536329) ok source "0x48(%rbp)" (0x00000048) not located in a known VMA region (needed readable region)! destination "%r8" ok SegvReason: reading NULL VMA What can I do to help you debug these issues? I really like Enpass and would like it to be stable again. Edited March 14, 20206 yr by sxc4567
March 17, 20206 yr Hi @sxc4567 Sorry for the trouble you are going through. Please let us know the scenario of what steps you are doing when an app crashes. Also, please write your name in the crash report and share it with us so that we can investigate further.
March 17, 20206 yr Author Hi Pratyush, Thanks a lot for your reply! I have just submitted a crash report that occurred with the typical pattern of invoking Enpass from Firefox - to fill out a login form - using the hotkey. I have included this thread's URL in the crash report and will be repeating this process for a week or so. I hope this method works for you; let me know if you need anything else or a different way of flagging those issues. Cheers!
March 18, 20206 yr Hi @sxc4567, Thanks for sharing crash report. I have noted down this issue and notified the QA team to look into it. Thanks for your co-operation.
April 4, 20206 yr Author Hi @Pratyush Sharma, I must have submitted at least 20 crash reports with this thread mentioned in the comments over the last couple of weeks; and that's not even all the crashes I encountered. Basically Enpass crashes on average at least 2-3 times a day. Perhaps a couple of specific aspects from my setup that may or may not matter: I have three vaults in my Enpass setup Each is synchronized with a WebDav server. Let me know if you need anything else from me? Happy to run debug versions etc to try and get to the bottom of this if this is helpful.
April 20, 20206 yr Author @Pratyush Sharma is there a way I can disable the crash reporter please? I suppose that by now you have enough of my reports (must be 50 or so...) and I certainly have enough of having to go through the reporter several times a day, as this only serves to exacerbate the impact on my workflow. Many thanks!
April 20, 20206 yr Hey @sxc4567 We are really sorry for the trouble you are having. Our team is looking into this. Please give some more time. Thanks for the patience.
June 25, 20206 yr Author Hi @Garima Singh, It's been over three months and I still face Enpass crashing several times every day on me on stock Ubuntu 20.04. It's come to the point where I dread having to log on to any website as I know by instinct this will very likely cause a 30+ seconds interruption in my workflow while Enpass takes its time to crash, present me with the crash reporter (have you been getting those???) and finally comes back up... As suggested previously, I'm most happy to help you debug this issue in any practical way. Otherwise I would really appreciate an ETA for a fix. I noticed that the Linux desktop version is a couple of minor versions behind Windows...
June 26, 20206 yr Hi @sxc4567, Sorry for the trouble you are going through. We are working on this, please allow us some more time. Thanks for your co-operation.
September 10, 20206 yr Hi @sxc4567, We've released an updated version of Enpass for Linux platform in which we have fixed this issue. Could you check that the issue is resolved. We'd love to have your feedback. Thanks for the co-operation.
September 10, 20206 yr Author Hi @Garima Singh, Thank you for following up. I suggest we continue in the new thread, which I see you've also commented on: Enpass beta 6.5.0 (701) MUCH more stable but crashes still
