March 24, 20206 yr Hi. I am new to Enpass and I have a problem with autofill (Safari and Firefox). I have checked the "Autofill details without showing Enpass Assistant" checkbox but autofill always shows the Assistant and I have to double click on the entry. I tested this on different websites, some with one login, some with 2 different logins. The behavior is identical with keyboard shortcut or contextual menu. Is it a known bug ? Thanks in advance.
March 25, 20206 yr Hi @denisbg Welcome to the forum! I would like to share that this feature works with the keyboard shortcut when there is only a single matching item in the Enpass. Please refer to this link for better understanding. To auto-fill the item automatically, please use the keyboard shortcut method. Thanks.
May 25, 20206 yr Hello, i have the same behaviour on my Mac even when there is only one matching item. It seems the automatic fill is broken when there is more than one vault (i have two). Is there a way to get this solved? thx
May 25, 20206 yr Hi @Ulmisch, Thanks for writing in. I have noted down this issue and notified the QA team to look into it. Thanks for your co-operation.
October 13, 20206 yr I also have this issue on Mac with more than one vault. Is there any progress? Thank you!
