April 21, 20206 yr I came over to enpass.io from DataValut, and DataVault had a great feature to "copy without spaces". E.g. if you have your bank card number in DataVault, "1234 5678 9901 1123", "Copy without spaces" would copy "1234567899011123" into the clipboard instead of "1234 5678 9901 1123". This was fantastic as it kept numbers more human-readable in DataVault, but allowed them to be keyed without spaces as is required by many sites. Can this be added to enpass.io?
April 22, 20206 yr Hey @tendim Thanks for using Enpass and writing to us. We really appreciate you for exploring the app and giving time in finding this valuable suggestion. The suggestion has been noted and forwarded to the development team for further consideration. Thanks for the amazing suggestion!
April 28, 20205 yr On 4/21/2020 at 6:36 PM, tendim said: I came over to enpass.io from DataValut, and DataVault had a great feature to "copy without spaces". E.g. if you have your bank card number in DataVault, "1234 5678 9901 1123", "Copy without spaces" would copy "1234567899011123" into the clipboard instead of "1234 5678 9901 1123". This was fantastic as it kept numbers more human-readable in DataVault, but allowed them to be keyed without spaces as is required by many sites. Can this be added to enpass.io? Another way of slicing this would be to have an input mask of some kind for numbers usually broken up, such as credit cards and SSNs.
April 29, 20205 yr Hi @beardedmogul, Thanks for writing in. I have noted down your input and notified the concerned team.
May 4, 20205 yr I'd love something like this as well. I like to store credit card numbers with spaces for easy readability, but so many websites cannot handle a credit card number entered with spaces. I've had to work around this by storing a 'no spaces' copy of the credit card number in another field that I specifically use for this purpose.
May 4, 20205 yr Hey @Anthony Thanks for writing to us. We appreciate your support on the same. Please note that we already have a feature request for this feature which is aligned for implementation in the future. However, we’re not sure of a specific timeline when this will be implemented. Thanks.
