Solved: Syncing at two locations?
Hello, please help in this regard:
I have been using Enpass for two years, syncing via local WIFI-WebDAV (to/from my iMac): iMac, MacBook, iPhone. Works like a charm. This is all at my home location.
A year ago I got myself a new iMac, transferred also the vault and moved the older iMac to another town. Now also I want to sync my current main vault (from the iPhone) with the older iMac in the other town. At the other location I of course have a differnt WIFI, therefor I would have to set up WIFI-WebDAV-syncing with the iPhone there.
My concern is: When I set up WebDAV to sync between the older iMac (old vault) and the iPhone (current vault), will syncing update the older iMac with the currrent vault (what of course I want) or could I end up having the older vault (from the older iMac) on my iPhone?
Asked in another way: What determines in which direction the syncing happens? I want to update the old iMac´s vault, to be like the vault on the iPhone. Not the other way round.
Hoping I could explain well, thank you for input!
Robert
Edited by Roobert
Hey @Roobert
Thanks for writing to us.
Yes, you can sync your old vault of imac to current vault of iPhone via Sync. To do so, please follow the step-
  • Open Enpass on your old imac and go to Enpass settings --> Vaults --> Select the vault(which you wish to sync with iPhone) ---> Select 'Set up Sync' and choose a cloud details to sync your database.
  • Enter your cloud details, follow the instructions and wait till the sync is done.
  • Now open Enpass on your iPhone --> Go on 'Vaults' --> Select the vault (which you wish to sync with imac) ---> Select the cloud (as in Step 1) from which you had enabled sync on your imac.
  • Once the sync is done, all your databases from imac will be restored in your iPhone.
Thanks!
Solved. I took a SuperDuper clone of my HD at home to the other town. Then, on the older iMac there, I set up „folder sync” with the „Enpass backup”-Folder on the SuperDuper clone HD. Thats all. Thanks for listening. ;-)
Hey @Roobert
Thanks for notifying us and sorry for the delay in response.
I m glad to know that you have managed to resolve the issue by yourself.
Thanks.
