June 3, 20206 yr Hi, I'm not starting to use Enapas on my Macbook pro as well. Sometimes when i open Enpas from the notification area (Windows) and now from the topmenu (on OSX) i use the short command (Command+E) to open the full view. On Windows when i authenticate using Windows Hello (TouchID) using the mini view and then open the full view using (CTRL+E) then i dont have to authenticate again since i have already done so. On MAC however its not working correctly. When i authenticate in mini view and open the full view it ask me to authenticate once more. Why? It is really annoying to be honest. And the worst is that it dont accept touchID directly, just like windows i have to click on the icon to the right side to even prompt for touchID. This seems like a bug to me. It cant be the expected behaviour? My OSX is Catalina and 6.4.2 for the app which is the latest.
June 3, 20206 yr Hey @vampyren Thanks for reporting this issue. I have noted down this issue and notified the QA team to look into it. Thanks for your cooperation.
June 4, 20206 yr Hey @vampyren Our QA team is trying to reproduce the issue. Will get back to you if we need any other info or if we receive any update. Thanks for your co-operation.
November 3, 20206 yr Hey @vampyren Thanks for the patience. Our team has fixed similar issues in the v6.6 of Enpass. Please wait for this version to be released and then share your findings with us. We'd love to have your feedback.
November 8, 20205 yr Author Sure. Hope its fixed for the last time. Always work on mSecure so it cant be a huge thing.
