August 21, 20206 yr I've set the Webform mapping field to email, but the browser extension still fills in the username information. Enpass v6.4.0 (649)
August 21, 20206 yr Hi @bestpika, That is a strange behavior. Could you share the website on which you face this problem? Additionally, you seem to be using an old version of Enpass. If you're on the Windows platform, update Enpass and verify the problem resolves.
August 22, 20206 yr Author @Pratyush Sharma The login page of the website can be found at https://accounts.pixiv.net/login. In Enpass I have filled in the username, email fields, and in webform I bind the login field to email. I'm using the portable version, it's the latest version on the download page. PS. I found the Android version (with Chrome) has the same problem... Edited August 22, 20206 yr by bestpika
August 24, 20206 yr Hey @bestpika Thanks for sharing the details. I have noted down this issue and forwarded all the inputs to the QA team to look into it. Will get back to you if we need any other info. Thanks for the co-operation.
August 27, 20206 yr Hey @bestpika Thanks for the patience. We would like to share that the issue has been reproduced by the QA team. Now our Dev team is looking into this issue to resolve and hopefully, a fix will be available in the future version of Enpass. Thanks for your co-operation.
