August 29, 20206 yr The default field will change its name according to the language of the program interface, but if I add my own field, I can't change the display name according to the language of the program even if the name is the same. So I would like to know if there is a way to create the same field as the default field to change the display name according to the language of the program interface? Thanks.
August 31, 20206 yr @bestpika That shouldn't be the case. You can click on the field name, and edit the name as you wish. Moreover, which language are you using in Enpass, and which particular field you're trying to create while you face this problem?
