August 29, 20206 yr after moving from my macbook pro (Mojave) to MacMini (Catalina 10.15.6) enpass can no longer be started with the global hotkey, not even with a right click on the mouse. But in the browser (Safari) it works. I have deleted enpass and reinstalled it, it does not work. Enpass is installed in the menu bar, but cannot be started with the hotkey. Can anyone help me? Thanks :-)
September 1, 20206 yr @ArminB Try to setup hotkey in Enpass General settings again and make sure Enpass is running in the background.
September 1, 20206 yr Author Thank you. I have now selected another key, Enpass can now be opened with the hotkey. Pasting the password works in the browser, but not in other apps, for example evernote. the password is not applied. I have to copy and paste the login data with copy and paste now.
September 3, 20206 yr Hi @ArminB, Are you trying to auto-fill using the Enpass assistant or are you using the keyboard shortcuts to copy the password from the Enpass app? Please note that the former is not a possibility as Enpass can't auto-fill in the desktop applications as of now.
September 3, 20206 yr Author Hi @Pratyush Sharma, thank you for your answer. I would like to auto-fill in the desktop applications. With mojave it worked, didn't it? is there a chance that it will work again in the future?
September 4, 20206 yr Hi @ArminB, We appreciate your efforts in helping us with the suggestions for improvement. We have taken a note of your feedback and notified the team to look into it. Thanks.
