August 31, 20206 yr I have seen references in some of the postings to "custom logos" or "custom icons" that can be added to the choose icon database. How is this done? I need instructions on how to create custom logos and icons, how to add them or delete them from the database, etc. Also, I read a few comments on Favicons but no instructions on how to access, use them, save them, etc. I would also like to be able to save some icons from the internet and save them as available icons for use in Enpass. Any help on the above items would be appreciated. Thank you.
September 1, 20206 yr @golfball Thanks for showing interest in using custom icons for Enpass. You can find the details for enabling website icons and custom icons for login items here.
September 9, 20206 yr golfball – As a bit of further info. Images work best if square or inside a square frame. Try to keep images at around 600 x 600 or smaller. Jpeg or png can be used if app theme is white, if app theme is black, png images look the cleanest. GIMP image editor is very effective at converting ico files (common for logos) to a png file and place rectangular logos within a square frame so it's correctly displayed within Enpass. I’ve attached an alternative transparent Google logo as an example.
November 18, 20205 yr Could you specify what the correct pixel size of the custom icon file should be? (so that it is not shrinked or expanded)
November 20, 20205 yr Hey @MarcSupilami Welcome to the forum! Correct pixel size depends on the display screen and the device you using. Thanks!
