May 18, 20215 yr Details: Windows 7 Professional SP1 64 bit Enpass 6.6.1(809) I did recently update, but the issue did not start at the time of the update, but a little later. Yes a 2 monitor setup Restart did not solve the problem I have been experimenting. I still had the 6.6.0 install files on the machine, so removed enpass 6.6.1 and installed 6.6.0. The problem was gone. I then upgraded to 6.6.1 and the problem is still gone. I will report back if it reappears.
September 16, 20215 yr Good morning, I have been experiencing the same issue for several months. Please see the attached image. I have a multi-monitor setup, win10, enpass 6.7.2 The problem began after an update. Uninstalling and reinstalling Enpass did not fix the problem.
September 16, 20215 yr Hi @Aliased Welcome to the Enpass Community! Thank you for sharing this issue with us. I have forwarded it to the concerned team. While we work on this concern for you, advise you to refer this link and follow the steps. Let me know if it works for you. Cheers!
September 17, 20215 yr On 9/16/2021 at 5:46 AM, Abhishek Dewan said: Hi @Aliased Welcome to the Enpass Community! Thank you for sharing this issue with us. I have forwarded it to the concerned team. While we work on this concern for you, advise you to refer this link and follow the steps. Let me know if it works for you. Cheers! This did not solve the issue.
September 20, 20215 yr Hi @Aliased, Thank you for informing me. Let me share this with the testing team and ask them to provide any fix/update. Enpass appreciates your patience!
September 23, 20215 yr Hi @Aliased Thank you for your patience .Our concerned team has identified the bug where some graphic drivers cause issues while rendering text in Qt (GUI framework Enpass uses). We are testing a patch provided by the upstream vendor for resolution. A fix will be available in the future Enpass update. Appreciate your co-operation.
July 5, 20224 yr Author Thanks, with the latest release the display is perfect again Edited July 5, 20224 yr by Rudi
