September 12, 20206 yr Hello, I has some trouble with a login into a local NAS from QNAP. The login-windows has two input fields ( username and passwort). I always get only the passwort filled into the login-windows, not the user name. Than I looked into the web formular and there is only the passwort field. How can get the user field as well into the formular? Or if this is not necessayr, how can I get both needed fields filled out by enpass? Karl Edited September 12, 20206 yr by KHK
September 15, 20206 yr @KHK On 9/12/2020 at 4:45 PM, KHK said: I always get only the passwort filled into the login-windows, not the user name. Make sure that you save the username in the correct field type (as Username) in Enpass. On 9/12/2020 at 4:45 PM, KHK said: Than I looked into the web formular and there is only the passwort field. How can get the user field as well into the formular? Just create a login entry in Enpass with the username, password and the URL of the particular site.
September 17, 20206 yr Author On 9/15/2020 at 3:33 PM, Kashish said: Make sure that you save the username in the correct field type (as Username) in Enpass In Enpass is the filed slect as username (Benutzername) and the password as passwort (Passwort) - but nevertheless it just take over the passowrt entry into the input-box - not the username
September 18, 20206 yr Hi @KHK, Sorry for the inconvenience caused to you. To further investigate this issue, please try to manually save the username of this item and check if the username and password get autofill. If you face any problems in autofill, share the URL with us to check the issue at our end. Thanks for your co-operation.
September 19, 20206 yr Author Hello, if I ente rthe username manually into the field I can add the passwort by enpass...the username is already in enpass, it will just not taken over into th elogin-window. Additionally I tried already different kind of URL's: - IP:Port/cgi-bin - IP:Port - http://IP:Port None of them has been working. As I had two local QNAP-units I tried it as well on the second one - with the same result - the username will not copy over into the login-field. The units are only accessable locally, sri no external access possible . Attached thow the fields are configured - is there anything you see, what could be the reason for not using the username? Tnx
September 22, 20206 yr Hey @KHK Thanks for the details. As we can't open the webpage for debugging, please navigate to that login page and save that page and also share the file with us. For saving a webpage follow this link. Note: When the webpage is saved, a folder and an HTML file is generated. Please share both with us. Thanks for the co-operation!
September 23, 20206 yr Author 22 hours ago, Garima Singh said: Hey @KHK Thanks for the details. Please share both with us. How can I upload the files? The folder contains data with other types! Is there a way to upload anywhere else?
September 24, 20206 yr Hey @KHK You can zip the HTML file and the folder into a zip file and then upload it. Please share it via mail at support@enpass.io along with this Forum link. Thanks!
