October 11, 20206 yr I imported all my logins via a csv file. Now all logins are a standard login. I want to change my twitter account from standard to twitter. (like for a new entry, where i can chosse login -> twitter) Edited October 11, 20206 yr by axelf
October 12, 20206 yr Hi @axelf, Thanks for using Enpass and writing to us. Currently, there is no option to change to a specific login category(like Amazon or Twitter) for an existing item. However, we have noted down your valuable suggestion for consideration in the future.
October 23, 20206 yr Hey @axelf Thanks for the patience. Please try this link to import the data and share the below detail if the problem issue persists- What kind of functionality you are lacking in imported data? Also, share the demo csv format through which you imported?
October 26, 20206 yr Author Hi @Garima Singh i did it like in the video but after importing all entries are standard logins. E.g. my twitter account is a standard login. If i had manually added this entry i had selected the twitter template and not the standard. B importing it via a csv file i can only have standard logins
October 27, 20206 yr Hi @axelf, Thanks for writing back in. We have taken note of this and our team is now analyzing it. If you have any further queries, please feel free to contact us.
November 2, 20206 yr Hey @axelf While the team is looking into it. Meanwhile, we recommend you to follow these steps and let me know if this is useful. Step 1: Download the previous version of Enpass5 from this link. Import the data into Enpass 5. Step 2: (After successfully completing the above steps please perform below steps). Take the backup of Enpass 5 data and save it manually on the device. Open Enpass 6 --> Take the backup of Enpass data and save it manually on the device. Open Enpass 6 -->Settings --> Advanced --> Apply Erase Everything function. Now open Enpass 6 and restore Enpass 5 backup file. Hope this helps!
