October 15, 20206 yr It is an interesting bug. If you want to delete a word from the title which is not the last word, the deletion continues from the end of the title. I explain it... For example you have an item called "Enpass password". If you want to delete the "Enpass" word, move your cursor to after the last "s" letter and push the delete key several times. After you delete the "Enpass" the cursor goes to the end of the title and the deletion continues, so you start to delete the "password" word as well. I can find it only in the Title field and when you start the deletion exactly the end of the word. Please look at it.
October 16, 20206 yr Hi @Krisz, Thanks for reporting this issue. We are able to reproduce this issue at our end, and our team is working on it. Hopefully, the fix will be available in future updates. Till then, we will request you to please co-operate with us. Thanks!
February 8, 20215 yr Hi @Krisz, Thanks for notifying us. I'm glad to know that the problem has been resolved. If you have any further queries, please feel free to contact us.
