October 20, 20206 yr Hi, I have two macs and I want to share a secondary vault between them with different sync accounts. I've managed to set up the two vaults but when I try to sync the secondary vault on the other mac, Enpass crashes (version 6.5.2). I've tried different sync accounts (drive, dropbox) but to no avail. Any thoughts on the issue?
October 21, 20206 yr Hey @llutjens Welcome to the forum! To sync/restore your Enpass database so that you can access and edit the same database saved in Enpass on your 2 devices, follow the steps mentioned below- Open Enpass on your macOS device1 and go to Enpass settings --> Click on 'Vaults' --> Select the vault---> Select ‘Set up Sync’ and choose a cloud account to your database. Enter your cloud account details, follow the instructions, and wait till the sync is done. Open Enpass on your macOS Device2--> Click on Restore from the particular cloud with which you have synced in step1 --> Login the cloud account--> Click on Continue --> Enter the master password (same you using on macOS device1)--> Tap on 'Continue'. Once this is done, the database from your macOS Device1 will be restored on your macOS device2. Also, you can refer to this FAQ. Let me know if you have any queries. Thanks!
October 27, 20206 yr I am having the same issue, it only happens when I add a second vault, the first one synced flawlessly.
October 28, 20206 yr Hi @DanRook, Unfortunately, from your comment, we could not quite understand what problem you are facing. Please share some more details so that we can assist you better. A screenshot, if possible would be great.
October 30, 20206 yr On 10/28/2020 at 2:13 AM, Pratyush Sharma said: Hi @DanRook, Unfortunately, from your comment, we could not quite understand what problem you are facing. Please share some more details so that we can assist you better. A screenshot, if possible would be great. Sorry @Pratyush Sharma I was not clear. I've installed Enpass for MacOs Catalina form the Apple Appstore and synced with Dropbox my personal vault (everything is OK with that). Then I tried to add my work vault synced with GDrive, the link on the browser opens correctly but when I accept notification on the browser to open Enpass the Enpass App freezes and I have to force quit. I've already tried many variations of the process. 1. I've synced first my work vault (with GDrive) and Enpass also freezes on the process of adding a second vault. 2. I've tried with another browser (Chrome, Safari and Opera) 3. I've tried reinstalling Enpass many times
November 3, 20206 yr Hey @DanRook Thanks for sharing the details. This is very odd. It's been shared with the team so that they can more thoroughly analyze the issue. Will get back to you as we receive any update.
November 10, 20205 yr Hi @DanRook, Please let us know if you see the crash dialog on the next restart? If yes, try restarting the app and then share the crash report which appears. We would recommend you to put this forum post link or the issue in the report's description, it will be helpful for us to identify the issue. Thanks!
November 24, 20205 yr On 11/10/2020 at 2:47 AM, Pratyush Sharma said: Hi @DanRook, Please let us know if you see the crash dialog on the next restart? If yes, try restarting the app and then share the crash report which appears. We would recommend you to put this forum post link or the issue in the report's description, it will be helpful for us to identify the issue. Thanks! Please give me an email address where i can send you an email with a link to a screen recording.
November 25, 20205 yr Hi @DanRook, Please share the video of the issue with us at support@enpass.io, so we can help you better. Thanks!
November 25, 20205 yr 13 hours ago, Pratyush Sharma said: Hi @DanRook, Please share the video of the issue with us at support@enpass.io, so we can help you better. Thanks! Ready the email has been sent
February 4, 20215 yr Hi, I have a similar issue: - my first vault synced with main iCloud account is ok - second vault synced with another iCloud account, or new created, show spinning wheel and Enpass hang This happens on my new MacBook Air with M1, before it was ok on a MacBook Pro with Intel i7.I also started with a clean install, but always spinnig wheel... Thanks! P.S. I have crash report but I can't attach here ....
February 5, 20215 yr Hi @FabriZ, Sorry for the inconvenience caused to you. Please let us know if you see the crash dialog on the next restart? If yes, try restarting the app and then share the crash report which appears. We would recommend you to put this forum post link or the issue in the report's description, it will be helpful for us to identify the issue. Thanks!
February 5, 20215 yr Hi, thank you, I sent now email with report crash in attach to support@enpass.io . Have a nice day! Fabrizio
