November 14, 20205 yr Hi, Found another annoying bug! IT only happens in Enpass too. I did not report it earlier but its getting more annoying by the day since i sign up to several sites as of late. I have a Logitech G915 keyboard where i have set a macro for one of the keys called G1. When i press this G1 it will type my email where ever i am, be it on the web, in a word file or any other program. But for some reason in Enpass in the Email field or any field for that matter when i press the G1 it will type vvvvvvvvvvvvvvvvvv instead of my email. The number of characters matches the email exactly but the result is just the first letter of my email typed like that. Why is Enapass the only program behaving different from everything else? ps. i even added a delay before typing the macro but no help. Please fix this.
November 17, 20205 yr Hey @vampyren Thanks for sharing this. We regret the problem you are facing, but we’re here to help. To do so, please share the following details: On which device and OS version are you having this issue? Which Enpass version are you using on the same device?
November 17, 20205 yr Author Thanks! This is on a windows 10 (latest patch v2004). Enpas also latest version 6.5.2. I has never worked really with the macro key but got really annoyed now so i reported it. Also since this is the only program it fails to work in.
November 20, 20205 yr Hey @vampyren Thanks for sharing the required inputs. We'll look into this issue at our end and keep you posted on further developments.
