December 8, 20205 yr Hello, I recently purchased enpass. Since then, I changed a lot of weak passwords. Problem is, a lot of them still show up under the "weak passwords" section. This occurs on my desktop app and iOS app as well. Is this a known bug or am I doing something wrong here? Same problem under "identical passwords": Passwords show up as identical, even when I changed them a long time ago and they are unique now. Screenshot Thank you!
December 9, 20205 yr Hi @Trendsetter, Welcome to the forums! Please revert to us with the answer to the following queries and we will get it sorted out for you: On which devices and OS versions (mention all) are you using Enpass? Which Enpass version are you using on each device?
December 9, 20205 yr Hi @Pratyush Sharma I am using enpass 6.5.2 (724) (microsoft store version) on a windows PC. Also I am using a iPhone SE 1st gen, a iPhone 12 Pro and a iPad 10.5 Pro, all running on iOS 14.2.1 and enpass 6.5.3.
December 10, 20205 yr Hi @Trendsetter, Thanks for sharing the details. We have taken note of this and our team is now analyzing into the issue.
December 10, 20205 yr I figured out that this has to be a problem with the history feature. Enpass seems to look up old history entries and not the current fields to tell me it's a weak or identical password. Is there a way to clear the history of all obsolete vault entries?
December 14, 20205 yr Hey @Trendsetter Thanks for the analysis and sharing your inputs to help us understanding the issue clearly. Please be informed that deleting password history feature is currently not available. However, it is aligned for implementation in future.
