macOS Sierra Incompatible
I realize even as I type this that macOS Sierra is a beta operating system and shouldn't necessarily be supported.
However, I'm writing this because I had better luck using the current public version working, than this beta version.
Whenever, I launch the Enpass beta, it crashes almost as quickly as it launched.
Scott
3 hours ago, Ankur Gupta said:
Hello @scottrych,
We have tested Enpass beta version on macOS Sierra beta 2 (16A239m). We didn't encounter any problem. Please tell us the build version of macOS Sierra so that we can investigate the issue.
Hi Ankur,
I'm actually running 16A239j (are you on the public beta).
And Enpass version is 5.2.2 (50).  I can send the logs privately, if you'd like.
Thanks,
Scott
Hi Ankur,
I sent you a message with the crash log data.
Thanks,
Scott
Hi @Ankur Gupta,
I believe that I may have inadvertently fixed Enpass.
I was having some, (a bunch actually), problems with iCloud on my Mac Book with Sierra this morning.
I first disabled sync from Enpass so that I could get a password that I needed without it crashing.
I then reset the sync on it and so far, it appears to be working for me.  I did the same thing the other day, but I didn't reboot the other day while I was doing all of this.  (Today, I had to reboot for other reasons.)
I'll let you know if this is actually working properly after I've been able to use it for a day or two.
Thanks,
Scott
  • 1 month later...
I've upgraded to new macOS 10.12, may I know Enpass is it incompatible with it, coz iCloud sync was not working & app crashed.
pls advise.
thanks
Hi @Sprankie,
Sorry to hear about your trouble. We are already aware of this issue that in Mac OSX 10.12 iCloud sync causes the crash. Our dev team is working on this issue and will try to fix it asap. Meanwhile you can try using other available cloud options to sync. Thanks for your cooperation.
Hi, I have the same issues..
I'm running the Golden Master of Sierra and when i open Enpass it crashes instantly. I have no way to get to my passwords and I'm stuck without being able to access some of the banking information that i need for my business. Do you have any idea how i can get at the info whilst waiting for a fix?
Many Thanks.
Hi all,
Sorry to hear your trouble. Our dev team is aware of this issue and we are working on it.
The best workaround at the moment is to disable iCloud sync. Before disabling sync, make sure Enpass is completely closed. You can disable sync via System Preferences ➝ iCloud ➝ iCloud Drive ➝ Tap Options ➝ Uncheck Enpass ➝ Click Done.
 icloud.thumb.png.b40a6a349eaf73bb0163922
Meanwhile you can also try using other available cloud options to sync.
cheers!
Hello - still Trouble to sync with iCloud - how is the Status - it takes much too long to fix it
to be clarify, it worked fine on Sierra, but after I created a new Credit Card today, it crashed everytime I enter Master Password.
Here's the crash log:
Process:               Enpass [60632]
Path:                  /Applications/Enpass.app/Contents/MacOS/Enpass
Identifier:            in.sinew.Enpass-Desktop
Version:               5.3.0 (57)
App Item ID:           732710998
App External ID:       818262424
Code Type:             X86-64 (Native)
Parent Process:        ??? [1]
Responsible:           Enpass [60632]
User ID:               501
Date/Time:             2016-09-21 14:32:50.565 +0700
OS Version:            Mac OS X 10.12 (16A320)
Report Version:        12
Anonymous UUID:        DE50CC43-6E7A-92A3-2408-6661E638309C
Sleep/Wake UUID:       1EA41501-8574-4982-B51E-23073762C87F
Time Awake Since Boot: 130000 seconds
Time Since Wake:       4700 seconds
System Integrity Protection: enabled
Crashed Thread:        18  Dispatch queue: com.apple.FileCoordination.3
Exception Type:        EXC_CRASH (SIGABRT)
Exception Codes:       0x0000000000000000, 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Application Specific Information:
abort() called
Thread 0:: Dispatch queue: com.apple.main-thread
0   libsystem_kernel.dylib        	0x00007fffe6eb2456 semaphore_wait_trap + 10
1   libdispatch.dylib             	0x00007fffe6d5e306 _dispatch_semaphore_wait_slow + 171
2   com.apple.Foundation          	0x00007fffd3932e7a -[NSFileCoordinator(NSPrivate) _blockOnAccessClaim:withAccessArbiter:] + 399
3   com.apple.Foundation          	0x00007fffd37c8a50 -[NSFileCoordinator(NSPrivate) _coordinateWritingItemAtURL:options:error:byAccessor:] + 775
4   com.apple.Foundation          	0x00007fffd37c8743 -[NSFileCoordinator coordinateWritingItemAtURL:options:error:byAccessor:] + 80
5   in.sinew.Enpass-Desktop       	0x00000001076d6b7d 0x10745b000 + 2603901
6   in.sinew.Enpass-Desktop       	0x00000001076d7317 0x10745b000 + 2605847
7   org.qt-project.QtCore         	0x0000000108b5c6dc QObject::event(QEvent*) + 156
8   org.qt-project.QtWidgets      	0x0000000107d14b76 QApplicationPrivate::notify_helper(QObject*, QEvent*) + 294
9   org.qt-project.QtWidgets      	0x0000000107d174c0 QApplication::notify(QObject*, QEvent*) + 5648
10  org.qt-project.QtCore         	0x0000000108b303f4 QCoreApplication::notifyInternal2(QObject*, QEvent*) + 164
11  org.qt-project.QtCore         	0x0000000108b31014 QCoreApplicationPrivate::sendPostedEvents(QObject*, int, QThreadData*) + 596
12  libqcocoa.dylib               	0x000000010b176bae 0x10b154000 + 142254
13  libqcocoa.dylib               	0x000000010b177481 0x10b154000 + 144513
14  com.apple.CoreFoundation      	0x00007fffd1cd9581 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 17
15  com.apple.CoreFoundation      	0x00007fffd1cba98c __CFRunLoopDoSources0 + 556
16  com.apple.CoreFoundation      	0x00007fffd1cb9e76 __CFRunLoopRun + 934
17  com.apple.CoreFoundation      	0x00007fffd1cb9874 CFRunLoopRunSpecific + 420
18  com.apple.HIToolbox           	0x00007fffd1259f6c RunCurrentEventLoopInMode + 240
19  com.apple.HIToolbox           	0x00007fffd1259da1 ReceiveNextEventCommon + 432
20  com.apple.HIToolbox           	0x00007fffd1259bd6 _BlockUntilNextEventMatchingListInModeWithFilter + 71
21  com.apple.AppKit              	0x00007fffcf9505f5 _DPSNextEvent + 1093
22  com.apple.AppKit              	0x00007fffd00608eb -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1637
23  com.apple.AppKit              	0x00007fffcf944fbd -[NSApplication run] + 926
24  libqcocoa.dylib               	0x000000010b17637f 0x10b154000 + 140159
25  org.qt-project.QtCore         	0x0000000108b2c7a1 QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 401
26  org.qt-project.QtCore         	0x0000000108b30a65 QCoreApplication::exec() + 341
27  in.sinew.Enpass-Desktop       	0x0000000107500275 0x10745b000 + 676469
28  libdyld.dylib                 	0x00007fffe6d8b255 start + 1
Thread 1:: Dispatch queue: com.apple.root.background-qos
0   libsystem_kernel.dylib        	0x00007fffe6eba3fe __unlink + 10
1   libsystem_kernel.dylib        	0x00007fffe6eb79cd unlink + 11
2   com.apple.AppKit              	0x00007fffcfb48a96 -[NSPersistentUICrashHandler clearCrashCountFileIfNecessary] + 75
3   com.apple.AppKit              	0x00007fffcfadf3c3 __51-[NSPersistentUIManager modifyCrashBlameCounterBy:]_block_invoke + 31
4   com.apple.AppKit              	0x00007fffd02f0aec ___NSPersistentUIDispatchQueueAsync_block_invoke + 31
5   libdispatch.dylib             	0x00007fffe6d5df5f _dispatch_call_block_and_release + 12
6   libdispatch.dylib             	0x00007fffe6d55128 _dispatch_client_callout + 8
7   libdispatch.dylib             	0x00007fffe6d57099 _dispatch_root_queue_drain + 917
8   libdispatch.dylib             	0x00007fffe6d56cb7 _dispatch_worker_thread3 + 99
9   libsystem_pthread.dylib       	0x00007fffe6fa1746 _pthread_wqthread + 1299
10  libsystem_pthread.dylib       	0x00007fffe6fa1221 start_wqthread + 13
Thread 2:
0   libsystem_kernel.dylib        	0x00007fffe6eba4e6 __workq_kernreturn + 10
1   libsystem_pthread.dylib       	0x00007fffe6fa17c5 _pthread_wqthread + 1426
2   libsystem_pthread.dylib       	0x00007fffe6fa1221 start_wqthread + 13
Thread 3:
1   libsystem_pthread.dylib       	0x00007fffe6fa1632 _pthread_wqthread + 1023
Thread 4:: Qt bearer thread
0   libsystem_kernel.dylib        	0x00007fffe6eb9c12 __pselect + 10
1   libsystem_kernel.dylib        	0x00007fffe6eb6815 pselect$1050 + 82
2   org.qt-project.QtCore         	0x0000000108b84147 qt_safe_select(int, fd_set*, fd_set*, fd_set*, timespec const*) + 103
3   org.qt-project.QtCore         	0x0000000108b85215 QEventDispatcherUNIXPrivate::doSelect(QFlags<QEventLoop::ProcessEventsFlag>, timespec*) + 693
4   org.qt-project.QtCore         	0x0000000108b863b7 QEventDispatcherUNIX::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 231
6   org.qt-project.QtCore         	0x0000000108972afe QThread::exec() + 110
7   org.qt-project.QtCore         	0x000000010897657a 0x10894e000 + 165242
8   libsystem_pthread.dylib       	0x00007fffe6fa1abb _pthread_body + 180
9   libsystem_pthread.dylib       	0x00007fffe6fa1a07 _pthread_start + 286
10  libsystem_pthread.dylib       	0x00007fffe6fa1231 thread_start + 13
Thread 5:
0   libsystem_kernel.dylib        	0x00007fffe6eb241a mach_msg_trap + 10
1   libsystem_kernel.dylib        	0x00007fffe6eb1867 mach_msg + 55
2   coop.plausible.CrashReporter  	0x000000010976e2a8 exception_server_thread + 202
3   libsystem_pthread.dylib       	0x00007fffe6fa1abb _pthread_body + 180
4   libsystem_pthread.dylib       	0x00007fffe6fa1a07 _pthread_start + 286
5   libsystem_pthread.dylib       	0x00007fffe6fa1231 thread_start + 13
Thread 6:: Dispatch queue: com.apple.root.background-qos
3   com.apple.AppKit              	0x00007fffd0392aa7 ___NSPersistentUIDispatchQueueAsync_block_invoke + 31
4   libdispatch.dylib             	0x00007fffe6d5df5f _dispatch_call_block_and_release + 12
5   libdispatch.dylib             	0x00007fffe6d55128 _dispatch_client_callout + 8
6   libdispatch.dylib             	0x00007fffe6d57099 _dispatch_root_queue_drain + 917
7   libdispatch.dylib             	0x00007fffe6d56cb7 _dispatch_worker_thread3 + 99
8   libsystem_pthread.dylib       	0x00007fffe6fa1746 _pthread_wqthread + 1299
9   libsystem_pthread.dylib       	0x00007fffe6fa1221 start_wqthread + 13
Thread 7:
Thread 8:
Thread 9:
Thread 10:: Qt HTTP thread
Thread 11:: Qt HTTP thread
Thread 12:: Thread (pooled)
0   libsystem_kernel.dylib        	0x00007fffe6eb9c8a __psynch_cvwait + 10
1   libsystem_pthread.dylib       	0x00007fffe6fa297a _pthread_cond_wait + 712
2   org.qt-project.QtCore         	0x0000000108977d2f 0x10894e000 + 171311
3   org.qt-project.QtCore         	0x0000000108977b6b 0x10894e000 + 170859
4   org.qt-project.QtCore         	0x0000000108977a42 QWaitCondition::wait(QMutex*, unsigned long) + 162
5   org.qt-project.QtCore         	0x000000010897353e 0x10894e000 + 152894
6   org.qt-project.QtCore         	0x000000010897657a 0x10894e000 + 165242
7   libsystem_pthread.dylib       	0x00007fffe6fa1abb _pthread_body + 180
8   libsystem_pthread.dylib       	0x00007fffe6fa1a07 _pthread_start + 286
9   libsystem_pthread.dylib       	0x00007fffe6fa1231 thread_start + 13
Thread 13:: com.apple.NSEventThread
0   com.apple.CoreFoundation      	0x00007fffd1c58ab5 CFDataGetBytePtr + 101
1   com.apple.SkyLight            	0x00007fffe324ff9a SLEventCreateFromDataAndSource + 89
2   com.apple.SkyLight            	0x00007fffe32534d7 CGSDecodeEventRecord + 77
3   com.apple.SkyLight            	0x00007fffe30e4dd1 CGSSnarfAndDispatchDatagrams + 1773
4   com.apple.SkyLight            	0x00007fffe30b7a3d SLSGetNextEventRecordInternal + 84
5   com.apple.SkyLight            	0x00007fffe324fdcd SLEventCreateNextEvent + 48
6   com.apple.HIToolbox           	0x00007fffd1263bcd PullEventsFromWindowServerOnConnection(unsigned int, unsigned char, __CFMachPortBoost*) + 102
7   com.apple.HIToolbox           	0x00007fffd1263b39 MessageHandler(__CFMachPort*, void*, long, void*) + 51
8   com.apple.CoreFoundation      	0x00007fffd1cc24dd __CFMachPortPerform + 253
9   com.apple.CoreFoundation      	0x00007fffd1cc23c9 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE1_PERFORM_FUNCTION__ + 41
10  com.apple.CoreFoundation      	0x00007fffd1cc2341 __CFRunLoopDoSource1 + 465
11  com.apple.CoreFoundation      	0x00007fffd1cba435 __CFRunLoopRun + 2405
12  com.apple.CoreFoundation      	0x00007fffd1cb9874 CFRunLoopRunSpecific + 420
13  com.apple.AppKit              	0x00007fffcfa9ce9e _NSEventThread + 205
14  libsystem_pthread.dylib       	0x00007fffe6fa1abb _pthread_body + 180
15  libsystem_pthread.dylib       	0x00007fffe6fa1a07 _pthread_start + 286
16  libsystem_pthread.dylib       	0x00007fffe6fa1231 thread_start + 13
Thread 14:: com.apple.NSURLConnectionLoader
2   com.apple.CoreFoundation      	0x00007fffd1cbaba4 __CFRunLoopServiceMachPort + 212
3   com.apple.CoreFoundation      	0x00007fffd1cba021 __CFRunLoopRun + 1361
4   com.apple.CoreFoundation      	0x00007fffd1cb9874 CFRunLoopRunSpecific + 420
5   com.apple.CFNetwork           	0x00007fffd0e8e144 +[NSURLConnection(Loader) _resourceLoadLoop:] + 313
6   com.apple.Foundation          	0x00007fffd36e630d __NSThread__start__ + 1243
Thread 15:
0   libsystem_kernel.dylib        	0x00007fffe6eb246e semaphore_timedwait_trap + 10
1   libdispatch.dylib             	0x00007fffe6d5e2c2 _dispatch_semaphore_wait_slow + 103
2   libdispatch.dylib             	0x00007fffe6d58a94 _dispatch_worker_thread + 275
Thread 16:: Qt HTTP thread
0   org.qt-project.QtNetwork      	0x00000001090e5caa DYLD-STUB$$QMetaObject::activate(QObject*, QMetaObject const*, int, void**) + 0
1   org.qt-project.QtNetwork      	0x000000010906fb6d 0x109012000 + 383853
2   org.qt-project.QtCore         	0x0000000108b635bd QMetaObject::activate(QObject*, int, int, void**) + 749
3   org.qt-project.QtNetwork      	0x00000001090356c8 0x109012000 + 145096
4   org.qt-project.QtNetwork      	0x00000001090359cc 0x109012000 + 145868
5   org.qt-project.QtCore         	0x0000000108b635bd QMetaObject::activate(QObject*, int, int, void**) + 749
6   org.qt-project.QtNetwork      	0x00000001090d94ef 0x109012000 + 816367
7   org.qt-project.QtCore         	0x0000000108b635bd QMetaObject::activate(QObject*, int, int, void**) + 749
8   org.qt-project.QtNetwork      	0x00000001090a79dc 0x109012000 + 612828
9   org.qt-project.QtNetwork      	0x00000001090b48ea 0x109012000 + 665834
10  org.qt-project.QtWidgets      	0x0000000107d14b76 QApplicationPrivate::notify_helper(QObject*, QEvent*) + 294
11  org.qt-project.QtWidgets      	0x0000000107d174c0 QApplication::notify(QObject*, QEvent*) + 5648
12  org.qt-project.QtCore         	0x0000000108b303f4 QCoreApplication::notifyInternal2(QObject*, QEvent*) + 164
13  org.qt-project.QtCore         	0x0000000108b85b03 QEventDispatcherUNIX::activateSocketNotifiers() + 195
14  org.qt-project.QtCore         	0x0000000108b856a5 QEventDispatcherUNIXPrivate::doSelect(QFlags<QEventLoop::ProcessEventsFlag>, timespec*) + 1861
15  org.qt-project.QtCore         	0x0000000108b863b7 QEventDispatcherUNIX::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 231
16  org.qt-project.QtCore         	0x0000000108b2c7a1 QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 401
17  org.qt-project.QtCore         	0x0000000108972afe QThread::exec() + 110
18  org.qt-project.QtCore         	0x000000010897657a 0x10894e000 + 165242
19  libsystem_pthread.dylib       	0x00007fffe6fa1abb _pthread_body + 180
20  libsystem_pthread.dylib       	0x00007fffe6fa1a07 _pthread_start + 286
21  libsystem_pthread.dylib       	0x00007fffe6fa1231 thread_start + 13
Thread 17:: com.apple.appkit-heartbeat
0   libobjc.A.dylib               	0x00007fffe64a19f0 objc_retain + 16
1   com.apple.CoreFoundation      	0x00007fffd1dacaa5 +[__NSSingleObjectArrayI __new::] + 69
2   com.apple.CoreFoundation      	0x00007fffd1c3c10e -[__NSPlaceholderArray initWithObjects:count:] + 158
3   com.apple.CoreFoundation      	0x00007fffd1c43a84 +[NSArray arrayWithObjects:count:] + 52
4   com.apple.AppKit              	0x00007fffcf9f021d -[NSAppearance _blendModeForWidget:] + 83
5   com.apple.AppKit              	0x00007fffcfb6b0cf -[NSProgressIndicator allowsVibrancy] + 195
6   com.apple.AppKit              	0x00007fffcf975d09 -[NSView(NSInternal) _needsVibrancy] + 83
7   com.apple.AppKit              	0x00007fffcf975b3f -[NSView(NSInternal) _updateVibrancy] + 26
8   com.apple.AppKit              	0x00007fffcfaad5fd -[NSView(NSLayerKitGlue) _drawViewBackingLayer:inContext:drawingHandler:] + 789
9   com.apple.AppKit              	0x00007fffcfaad2e2 -[NSView(NSLayerKitGlue) drawLayer:inContext:] + 80
10  com.apple.QuartzCore          	0x00007fffd79144f4 CA::Layer::display_() + 898
11  com.apple.AppKit              	0x00007fffcfaac1d6 _NSBackingLayerDisplay + 577
12  com.apple.AppKit              	0x00007fffcfa9f43c -[_NSViewBackingLayer display] + 885
13  com.apple.QuartzCore          	0x00007fffd79089a6 CA::Layer::display_if_needed(CA::Transaction*) + 572
14  com.apple.QuartzCore          	0x00007fffd7908ad1 CA::Layer::layout_and_display_if_needed(CA::Transaction*) + 35
15  com.apple.QuartzCore          	0x00007fffd78fe2e8 CA::Context::commit_transaction(CA::Transaction*) + 280
16  com.apple.QuartzCore          	0x00007fffd77f55e5 CA::Transaction::commit() + 475
17  com.apple.AppKit              	0x00007fffcfc19e12 -[NSUIHeartBeat _heartBeatThread:] + 2516
18  com.apple.Foundation          	0x00007fffd36e630d __NSThread__start__ + 1243
Thread 18 Crashed:: Dispatch queue: com.apple.FileCoordination.3
0   libsystem_kernel.dylib        	0x00007fffe6eb9dda __pthread_kill + 10
1   libsystem_pthread.dylib       	0x00007fffe6fa4797 pthread_kill + 90
2   libsystem_c.dylib             	0x00007fffe6e1f440 abort + 129
3   coop.plausible.CrashReporter  	0x0000000109762851 uncaught_exception_handler + 27
4   com.apple.CoreFoundation      	0x00007fffd1dbfe29 __handleUncaughtException + 745
5   libobjc.A.dylib               	0x00007fffe64b1b85 _objc_terminate() + 94
6   libc++abi.dylib               	0x00007fffe59a5d69 std::__terminate(void (*)()) + 8
7   libc++abi.dylib               	0x00007fffe59a5de3 std::terminate() + 51
8   libdispatch.dylib             	0x00007fffe6d5513c _dispatch_client_callout + 28
9   libdispatch.dylib             	0x00007fffe6d6bb97 _dispatch_queue_serial_drain + 896
10  libdispatch.dylib             	0x00007fffe6d5dd41 _dispatch_queue_invoke + 1046
11  libdispatch.dylib             	0x00007fffe6d56ee0 _dispatch_root_queue_drain + 476
12  libdispatch.dylib             	0x00007fffe6d56cb7 _dispatch_worker_thread3 + 99
13  libsystem_pthread.dylib       	0x00007fffe6fa1746 _pthread_wqthread + 1299
14  libsystem_pthread.dylib       	0x00007fffe6fa1221 start_wqthread + 13
Thread 19:: QThread
0   libsystem_kernel.dylib        	0x00007fffe6eb9f4e __select + 10
1   org.qt-project.QtCore         	0x0000000108b84303 qt_safe_select(int, fd_set*, fd_set*, fd_set*, timespec const*) + 547
2   org.qt-project.QtCore         	0x0000000108b85215 QEventDispatcherUNIXPrivate::doSelect(QFlags<QEventLoop::ProcessEventsFlag>, timespec*) + 693
3   org.qt-project.QtCore         	0x0000000108b863b7 QEventDispatcherUNIX::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 231
4   org.qt-project.QtCore         	0x0000000108b2c7a1 QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 401
5   org.qt-project.QtCore         	0x0000000108972afe QThread::exec() + 110
Thread 18 crashed with X86 Thread State (64-bit):
  rax: 0x0000000000000000  rbx: 0x0000000000000006  rcx: 0x0000700001398bb8  rdx: 0x0000000000000000
  rdi: 0x000000000001472b  rsi: 0x0000000000000006  rbp: 0x0000700001398be0  rsp: 0x0000700001398bb8
   r8: 0x0000000000000010   r9: 0x00007000013989f8  r10: 0x000000000c000000  r11: 0x0000000000000206
  r12: 0x00007fffec570b80  r13: 0x00007fee26912e00  r14: 0x0000700001399000  r15: 0x0000610000659560
  rip: 0x00007fffe6eb9dda  rfl: 0x0000000000000206  cr2: 0x000000011aa926ce
Logical CPU:     0
Error Code:      0x020000b8
Trap Number:     133
Binary Images:
       0x10745b000 -        0x107aecff7 +in.sinew.Enpass-Desktop (5.3.0 - 57) <9A60511F-46EF-3DE2-B89C-015D50E8A51B> /Applications/Enpass.app/Contents/MacOS/Enpass
       0x107b6b000 -        0x107c85fdf +libcrypto.1.0.0.dylib (0) <6A60BC71-F7DB-37A5-96EA-74BD4762E2DC> /Applications/Enpass.app/Contents/Frameworks/libcrypto.1.0.0.dylib
       0x107d04000 -        0x1081fcfff +org.qt-project.QtWidgets (5.6 - 5.6.0) <02077B7C-1880-31FD-91C5-343DE525ACCC> /Applications/Enpass.app/Contents/Frameworks/QtWidgets.framework/Versions/5/QtWidgets
       0x10836b000 -        0x108842ff7 +org.qt-project.QtGui (5.6 - 5.6.0) <559BD3C9-011A-32F1-B235-E489ADD804B9> /Applications/Enpass.app/Contents/Frameworks/QtGui.framework/Versions/5/QtGui
       0x10894e000 -        0x108e63fff +org.qt-project.QtCore (5.6 - 5.6.0) <E419E60B-6B80-3947-B8CD-70DB225B827D> /Applications/Enpass.app/Contents/Frameworks/QtCore.framework/Versions/5/QtCore
       0x108f29000 -        0x108fbdfe7 +org.qt-project.QtMultimedia (5.6 - 5.6.0) <34A6A3EA-CDF8-380B-8D53-8BE8C315C958> /Applications/Enpass.app/Contents/Frameworks/QtMultimedia.framework/Versions/5/QtMultimedia
       0x109012000 -        0x109119fff +org.qt-project.QtNetwork (5.6 - 5.6.0) <05DD8BDF-0CC6-3B1E-93D4-FB01D31277ED> /Applications/Enpass.app/Contents/Frameworks/QtNetwork.framework/Versions/5/QtNetwork
       0x109162000 -        0x10919bfff +net.hockeyapp.sdk.mac (3.0 - 27) <552B57DE-E183-3820-9DAD-0A254F39187A> /Applications/Enpass.app/Contents/Frameworks/HockeySDK.framework/Versions/A/HockeySDK
       0x1091de000 -        0x1091e6fff +org.qt-project.QtMacExtras (5.6 - 5.6.0) <1974D69C-B5CA-3374-A9BE-3C33CA7C02CA> /Applications/Enpass.app/Contents/Frameworks/QtMacExtras.framework/Versions/5/QtMacExtras
       0x1091f6000 -        0x10922afff +org.qt-project.QtXml (5.6 - 5.6.0) <D69E01DE-498F-31AF-8027-D1563BF580DD> /Applications/Enpass.app/Contents/Frameworks/QtXml.framework/Versions/5/QtXml
       0x10923e000 -        0x109269fff +org.qt-project.QtSql (5.6 - 5.6.0) <580A14D8-AAFD-360E-BA41-CC714E68CF15> /Applications/Enpass.app/Contents/Frameworks/QtSql.framework/Versions/5/QtSql
       0x109282000 -        0x1096b6fff +org.qt-project.QtXmlPatterns (5.6 - 5.6.0) <0CB19FF5-6CC0-3802-9B82-CEFEE32414C0> /Applications/Enpass.app/Contents/Frameworks/QtXmlPatterns.framework/Versions/5/QtXmlPatterns
       0x109719000 -        0x109738fff +org.qt-project.QtWebSockets (5.6 - 5.6.0) <B28AF983-08F8-39FC-A61F-BEF389EF7AAB> /Applications/Enpass.app/Contents/Frameworks/QtWebSockets.framework/Versions/5/QtWebSockets
       0x109750000 -        0x109754ffb  com.apple.agl (3.3.1 - AGL-3.3.1) <47E88CED-4D65-3579-A730-B576D3E41DFA> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
       0x10975e000 -        0x109787ff7 +coop.plausible.CrashReporter (1.0) <037FC6FA-6FB2-3584-9DD0-145D468013C9> /Applications/Enpass.app/Contents/Frameworks/HockeySDK.framework/Versions/A/Frameworks/CrashReporter.framework/Versions/A/CrashReporter
       0x10b154000 -        0x10b294fff +libqcocoa.dylib (0) <629D9B69-CDBE-3195-ADCE-1704FB10B67F> /Applications/Enpass.app/Contents/PlugIns/platforms/libqcocoa.dylib
       0x10b2de000 -        0x10b344ff7 +org.qt-project.QtDBus (5.6 - 5.6.0) <49B5334B-842F-36D5-AE01-17C5D0E463CC> /Applications/Enpass.app/Contents/Frameworks/QtDBus.framework/Versions/5/QtDBus
       0x10b360000 -        0x10b393ff7 +org.qt-project.QtPrintSupport (5.6 - 5.6.0) <D3154B8C-707E-35FC-8A44-A192AC07EA11> /Applications/Enpass.app/Contents/Frameworks/QtPrintSupport.framework/Versions/5/QtPrintSupport
       0x10b7c1000 -        0x10b7cbff7 +libqdds.dylib (0) <CF3E7CD3-EE7A-3ACC-8F53-F2BB460C38C4> /Applications/Enpass.app/Contents/PlugIns/imageformats/libqdds.dylib
       0x10b7d2000 -        0x10b7d8ff7 +libqgif.dylib (0) <D2A45CD7-2871-3C5A-BC34-7EC3486434A8> /Applications/Enpass.app/Contents/PlugIns/imageformats/libqgif.dylib
       0x10b7df000 -        0x10b7e6fff +libqicns.dylib (0) <3EF511AD-672B-3DE4-84AE-F9DC94A1A5BD> /Applications/Enpass.app/Contents/PlugIns/imageformats/libqicns.dylib
       0x10b7ee000 -        0x10b7f3fff +libqico.dylib (0) <BFE76DB7-01C5-3044-B807-E6B96361DE96> /Applications/Enpass.app/Contents/PlugIns/imageformats/libqico.dylib
       0x10b7fa000 -        0x10b839fff +libqjpeg.dylib (0) <F8362E1B-D1E7-33DF-B771-397F5689EFC4> /Applications/Enpass.app/Contents/PlugIns/imageformats/libqjpeg.dylib
       0x10b843000 -        0x10b847ff7 +libqtga.dylib (0) <4A1CB974-F71D-37DF-B46C-DB1FAA434BC9> /Applications/Enpass.app/Contents/PlugIns/imageformats/libqtga.dylib
       0x10b84e000 -        0x10b8b2fff +libqtiff.dylib (0) <109B39F9-68CB-3AB6-9CA1-E6120DD6DA27> /Applications/Enpass.app/Contents/PlugIns/imageformats/libqtiff.dylib
       0x10b8be000 -        0x10b8c2ff7 +libqwbmp.dylib (0) <2B06A207-EBC6-363B-9F82-32A9A4553BF7> /Applications/Enpass.app/Contents/PlugIns/imageformats/libqwbmp.dylib
       0x10db27000 -        0x10db8aff7 +libqwebp.dylib (0) <094123A8-01C2-38F5-A462-C7BD47DC89A9> /Applications/Enpass.app/Contents/PlugIns/imageformats/libqwebp.dylib
       0x10dbd5000 -        0x10dbddfff +libqgenericbearer.dylib (0) <AC15F680-989F-3D36-9C59-D0F3BFDB3C8A> /Applications/Enpass.app/Contents/PlugIns/bearer/libqgenericbearer.dylib
       0x10dc5c000 -        0x10dc991c7  dyld (421.1) <A525EAEA-AF86-30C2-B360-3D093B4F0828> /usr/lib/dyld
       0x10e0b9000 -        0x10e0d5fff  com.apple.security.csparser (3.0 - 57740.1.18) <59FC4D03-99ED-3543-B26B-E466B074EAF9> /System/Library/Frameworks/Security.framework/PlugIns/csparser.bundle/Contents/MacOS/csparser
       0x10e76c000 -        0x10ec44fff  com.apple.driver.AppleIntelHD4000GraphicsGLDriver (10.18.65 - 10.1.8) <E7448943-FC24-3DD7-9864-3B5D07B00F9E> /System/Library/Extensions/AppleIntelHD4000GraphicsGLDriver.bundle/Contents/MacOS/AppleIntelHD4000GraphicsGLDriver
       0x10ee5d000 -        0x10eecdfff  com.apple.driver.AppleIntelHD4000GraphicsMTLDriver (10.18.65 - 10.1.8) <40FB170B-F33E-326B-9741-E15EFE731D71> /System/Library/Extensions/AppleIntelHD4000GraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelHD4000GraphicsMTLDriver
       0x112341000 -        0x112345fff  libFontRegistryUI.dylib (196) <8531768D-4B74-3CD6-992D-2FAC8E89F71B> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resources/libFontRegistryUI.dylib
       0x112ede000 -        0x112ee7ff7 +libqsqlcipher.dylib (0) <99C18061-3BB4-36E0-BD88-7BBFB2793F98> /Applications/Enpass.app/Contents/PlugIns/sqldrivers/libqsqlcipher.dylib
       0x112ef1000 -        0x112fa4fff +libsqlcipher.0.dylib (0) <EEA8B2A1-377D-3588-927B-ACF0815B1D81> /Applications/Enpass.app/Contents/Frameworks/libsqlcipher.0.dylib
       0x112fb7000 -        0x112fc9ff7 +libqtaudio_coreaudio.dylib (0) <8BE03FC5-8EC3-305A-9B53-BD44B99101C8> /Applications/Enpass.app/Contents/PlugIns/audio/libqtaudio_coreaudio.dylib
       0x112fd3000 -        0x112fd7fff  com.apple.audio.AppleHDAHALPlugIn (276.26 - 276.26) <E792FB29-7228-39E4-AA4E-9739F3E54800> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
       0x113006000 -        0x11316efff  com.apple.audio.units.Components (1.14 - 1.14) <695D3410-4177-3CC3-A419-1127ECC911C4> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
       0x1132aa000 -        0x1132abff1 +cl_kernels (???) <8DAC571F-275C-422C-9C3D-89C3A3825766> cl_kernels
    0x7fffcc984000 -     0x7fffcccbcfff  com.apple.RawCamera.bundle (7.00 - 874) <99AF1865-BCDD-3313-85BF-E246745201F0> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
    0x7fffcd2ac000 -     0x7fffcdaf8fff  com.apple.GeForceGLDriver (10.12.65 - 10.1.2) <6AF074C0-3325-3889-A3B0-7253D4383C29> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
    0x7fffcdaf9000 -     0x7fffce3c7ff3  libclh.dylib (4.0.3 - 4.0.3) <035FC9AA-7ED0-35ED-8951-0184C530027C> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
    0x7fffce3c8000 -     0x7fffce4d8ff7  com.apple.GeForceMTLDriver (10.12.65 - 10.1.2) <81626155-E747-3405-BCD7-244BAC72DC00> /System/Library/Extensions/GeForceMTLDriver.bundle/Contents/MacOS/GeForceMTLDriver
    0x7fffce4d9000 -     0x7fffce697fff  com.apple.avfoundation (2.0 - 1183.3) <E6DCAB50-ECD4-3645-8A93-D14F14092DC4> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
    0x7fffce698000 -     0x7fffce73bff7  com.apple.audio.AVFAudio (1.0 - ???) <18E472FC-5AD7-33B8-8D46-49D5AC2DB13A> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
    0x7fffce7ce000 -     0x7fffce7cefff  com.apple.Accelerate (1.11 - Accelerate 1.11) <BDDB2053-BB24-34E4-A452-50D1260BF672> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x7fffce7cf000 -     0x7fffce7e6ff3  libCGInterfaces.dylib (331.4) <2CD05A85-79AC-3C67-9ABE-00294CE1C82B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
    0x7fffce7e7000 -     0x7fffcee27fe3  com.apple.vImage (8.1 - ???) <6CC22156-EC5C-3DC3-8132-41376F090B08> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x7fffcee28000 -     0x7fffcefeffef  libBLAS.dylib (1185) <0D55CF73-6DBD-3D15-B500-189479638551> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x7fffceff0000 -     0x7fffcf007fff  libBNNS.dylib (14) <43A9B06E-3C21-3CE6-B0C1-99DA172DEEB0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
    0x7fffcf008000 -     0x7fffcf413fff  libLAPACK.dylib (1185) <E7AE9C48-6E42-3EB7-A257-D48E0CB48D00> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x7fffcf414000 -     0x7fffcf42afff  libLinearAlgebra.dylib (1185) <08F00EFB-B477-3421-906E-3D364E607E6A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
    0x7fffcf42b000 -     0x7fffcf431fff  libQuadrature.dylib (3) <120F6228-A3D4-3184-89D7-785ADC2AC715> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
    0x7fffcf432000 -     0x7fffcf445ff7  libSparseBLAS.dylib (1185) <912E3D25-27C0-3245-B64C-3CAD43A5D633> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
    0x7fffcf446000 -     0x7fffcf593ff7  libvDSP.dylib (600) <87EF1D0A-1F85-31DD-AD8F-AB31E7D8E73B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x7fffcf594000 -     0x7fffcf64bfff  libvMisc.dylib (600) <F6EA539E-0A90-3F8A-9ECA-001E46394E29> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x7fffcf64c000 -     0x7fffcf64cfff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <B4B785D8-CB43-3E5D-AE81-1F27885AA112> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x7fffcf909000 -     0x7fffd05e0ff3  com.apple.AppKit (6.9 - 1504) <5524F97F-FB11-3556-8AC4-FF634C6CCCB7> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x7fffd05f2000 -     0x7fffd05f2fff  com.apple.ApplicationServices (48 - 48) <3E1395EA-C661-3318-9B87-9857BB81021B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x7fffd05f3000 -     0x7fffd0661ff7  com.apple.ApplicationServices.ATS (377 - 422) <521E41BF-D495-3233-B6BF-C0B83DD1A8C0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x7fffd06fb000 -     0x7fffd0829fff  libFontParser.dylib (194) <CDC6A0AA-E6AC-315B-AFBF-011F64548911> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
    0x7fffd082a000 -     0x7fffd0874fff  libFontRegistry.dylib (196) <3B8B0E78-2B30-3F18-B7D3-BE4E96F6BAF3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x7fffd08d1000 -     0x7fffd0903fff  libTrueTypeScaler.dylib (194) <E8B9E8E7-1F7A-3700-895C-501C12EDD001> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
    0x7fffd096f000 -     0x7fffd0a19ff7  com.apple.ColorSync (4.12.0 - 502) <C86F8032-83DD-34EB-A4CB-87E96F25CF1C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x7fffd0a1a000 -     0x7fffd0a6afff  com.apple.HIServices (1.22 - 589) <3167EF9C-F121-39EF-AAE2-7700E7128426> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x7fffd0a6b000 -     0x7fffd0a7aff3  com.apple.LangAnalysis (1.7.0 - 1.7.0) <47D1A017-91A4-37F3-93E0-3923CD6ED2DE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x7fffd0a7b000 -     0x7fffd0ac8fff  com.apple.print.framework.PrintCore (12 - 491) <B7CC15C1-AF50-37F3-8AF6-65F8CDC323F0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x7fffd0ac9000 -     0x7fffd0b04fff  com.apple.QD (3.12 - 310) <8F718290-DD82-36CE-9AF0-EFB6D31A49F4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x7fffd0b05000 -     0x7fffd0b10ff7  com.apple.speech.synthesis.framework (6.0.15 - 6.0.15) <23EA6076-ECDF-3A50-81E7-3CE6451DC8C4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x7fffd0b11000 -     0x7fffd0d1dfff  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <EDDC86C8-92F3-34C6-A5C1-A176ADA724C3> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x7fffd0d1e000 -     0x7fffd0d1efff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <AA9DB0D2-3B2F-3366-B451-DD9E89038F6F> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x7fffd0e87000 -     0x7fffd120afff  com.apple.CFNetwork (807.0.4 - 807.0.4) <A338A213-4FFF-3317-B4DB-84735C63C507> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x7fffd1224000 -     0x7fffd1224fff  com.apple.Carbon (154 - 157) <AB71A31F-5B15-3BF5-8532-591EACD07B21> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x7fffd1225000 -     0x7fffd1228fff  com.apple.CommonPanels (1.2.6 - 98) <DDA2DF0B-86E7-34B6-B688-D7371DBC8A63> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x7fffd1229000 -     0x7fffd152cfff  com.apple.HIToolbox (2.1.1 - 855) <AA4E2957-6B2D-3822-881C-0F64222F9578> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x7fffd152d000 -     0x7fffd1530ff7  com.apple.help (1.3.5 - 49) <27C5F9FE-838F-3807-A4AC-D99470185B10> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x7fffd1531000 -     0x7fffd1536fff  com.apple.ImageCapture (9.0 - 9.0) <E3E757FD-4060-33A4-A2AC-85EFBD987FCE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x7fffd1537000 -     0x7fffd15ceff3  com.apple.ink.framework (10.9 - 219) <B44BA36D-7549-3EB2-8CF6-E171885194FB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x7fffd15cf000 -     0x7fffd15e9fff  com.apple.openscripting (1.7 - 172) <B204BF70-C4AA-3699-8493-66E6645A92A8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x7fffd15ea000 -     0x7fffd15ebff3  com.apple.print.framework.Print (12 - 267) <CA7E9448-0903-34C8-AAF6-9070B52BF70E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x7fffd15ec000 -     0x7fffd15eeff7  com.apple.securityhi (9.0 - 55006) <856F4FB9-AAF2-3FC2-BE19-E7AB494232CC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x7fffd15ef000 -     0x7fffd15f5ff7  com.apple.speech.recognition.framework (6.0.1 - 6.0.1) <A20B0F7B-C32A-3FF1-BB75-BAC0EE4EF889> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x7fffd15f6000 -     0x7fffd16d4ffb  com.apple.cloudkit.CloudKit (638.1 - 638.1) <C81C2824-1E30-3887-A499-43755EDF27C7> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
    0x7fffd16d5000 -     0x7fffd16d5fff  com.apple.Cocoa (6.11 - 22) <5EEB0A26-F1C2-3D57-8441-52C0B80C2A6A> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x7fffd1808000 -     0x7fffd1898ff7  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <0352D931-596B-3AFE-B5C6-5925CF9F870E> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x7fffd1899000 -     0x7fffd18acff3  com.apple.CoreBluetooth (1.0 - 1) <73A2B185-70E4-3535-A653-E1BC74584E55> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
    0x7fffd18ad000 -     0x7fffd1ba7fff  com.apple.CoreData (120 - 752.2) <51AB540E-01AE-3207-8DE5-3E912FA9B5DF> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x7fffd1ba8000 -     0x7fffd1c34fff  com.apple.CoreDisplay (1.0 - 1) <F10E2F1A-FA51-3256-BCCE-34FF30AB1E3A> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
    0x7fffd1c35000 -     0x7fffd20c8ff7  com.apple.CoreFoundation (6.9 - 1348.1) <2A35BE4F-BA5B-3C22-BCF1-CFBBA2786081> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7fffd20c9000 -     0x7fffd2769ff7  com.apple.CoreGraphics (2.0 - 1070) <765D6A92-48AE-3CBB-9967-61300D715F1F> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x7fffd276a000 -     0x7fffd29a9ff7  com.apple.CoreImage (12.0.0 - 451) <84C71E9C-5231-342F-94B1-2BB6860E8AD3> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
    0x7fffd29aa000 -     0x7fffd2a06ff7  com.apple.corelocation (2100.3.13) <1064F400-1027-34D7-8F24-CDCB6DAF0F16> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
    0x7fffd2a07000 -     0x7fffd2ab7ff7  com.apple.CoreMedia (1.0 - 1903.7) <5FE3B4CC-EC1A-38FE-96FA-FFD419229F3E> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
    0x7fffd2ab8000 -     0x7fffd2b03ff7  com.apple.CoreMediaIO (801.0 - 4922) <2813BA18-E24C-3CFB-8B34-73575DFDF0BC> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
    0x7fffd2b04000 -     0x7fffd2b04fff  com.apple.CoreServices (775.8 - 775.8) <C36F7F47-D585-32F2-8A6F-7711935CDFD6> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x7fffd2b05000 -     0x7fffd2b56ff7  com.apple.AE (712 - 712) <0EF17D7E-6BA4-3555-BC38-9BD0CC5B82A3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x7fffd2b57000 -     0x7fffd2e32fff  com.apple.CoreServices.CarbonCore (1159 - 1159) <837B7ECF-7E62-3210-988C-63D7AB4EAA88> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x7fffd2e33000 -     0x7fffd2e66fff  com.apple.DictionaryServices (1.2 - 274) <302B8678-D057-3CF8-ACA7-7424A4A6A00A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x7fffd2e67000 -     0x7fffd2e6fffb  com.apple.CoreServices.FSEvents (1230 - 1230) <8836E7D0-844F-36F9-9601-B630BB82336B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
    0x7fffd2e70000 -     0x7fffd2fdbfff  com.apple.LaunchServices (775.8 - 775.8) <6E7CE1DA-27A4-3B48-A8E3-F2AA868ADD7C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x7fffd2fdc000 -     0x7fffd308cffb  com.apple.Metadata (10.7.0 - 1075) <9EDF10CF-1755-346A-A3C9-97642C443A58> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x7fffd308d000 -     0x7fffd30ecfff  com.apple.CoreServices.OSServices (775.8 - 775.8) <FCF1334F-D2D7-3C5A-A8FE-C173C5EDE586> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x7fffd30ed000 -     0x7fffd315dfff  com.apple.SearchKit (1.4.0 - 1.4.0) <F1B3EF8D-E820-317C-AC7F-8F056C246874> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x7fffd315e000 -     0x7fffd31a4ff7  com.apple.coreservices.SharedFileList (38 - 38) <6C5A3FBB-9502-3725-AC3A-AE7B1528BBD4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
    0x7fffd3231000 -     0x7fffd337cff7  com.apple.CoreText (352.0 - 544) <064B53E8-CD5A-3D1B-81DF-498A659FC20A> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
    0x7fffd337d000 -     0x7fffd33b2fff  com.apple.CoreVideo (1.8 - 234.0) <48C31E93-87C2-31F4-97E7-9E54C1EA8E7D> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x7fffd33b3000 -     0x7fffd3424ffb  com.apple.framework.CoreWLAN (11.0 - 1200.25.1) <F46EF4A2-C348-3F76-A1C2-B8A84C17FE2B> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
    0x7fffd351f000 -     0x7fffd3524fff  com.apple.DiskArbitration (2.7 - 2.7) <566D5C06-13E8-3638-B2EC-2B834D5F04F1> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x7fffd36b3000 -     0x7fffd3a5affb  com.apple.Foundation (6.9 - 1349) <08A463B1-296E-3AC1-B8D3-01A75B0785A8> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x7fffd3a86000 -     0x7fffd3ab7ff3  com.apple.GSS (4.0 - 2.0) <B30A0B99-AFDE-3BF8-A04F-761A75A6A3B1> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
    0x7fffd3b6b000 -     0x7fffd3c0effb  com.apple.Bluetooth (5.0.0 - 5.0.0f17) <E8BCB872-7806-3D07-B44A-8060D2581C9C> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
    0x7fffd3c0f000 -     0x7fffd3ca4fff  com.apple.framework.IOKit (2.0.2 - 1324.1.7) <10BDCD1E-0463-3C53-BF11-C9A0919C1588> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x7fffd3ca5000 -     0x7fffd3cabffb  com.apple.IOSurface (152 - 152) <558D4451-2D9D-3D47-B3A5-E7C18DF53F1B> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x7fffd3cac000 -     0x7fffd3cfeff3  com.apple.ImageCaptureCore (7.0 - 7.0) <EF8DF81D-3D82-3202-BE75-E49D38EC105D> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
    0x7fffd3cff000 -     0x7fffd3e58ff7  com.apple.ImageIO.framework (3.3.0 - 1570.1) <6B0177F3-A7BE-30D7-B075-7117E2C28A5F> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x7fffd3e59000 -     0x7fffd3e5dfff  libGIF.dylib (1570.1) <AE06146E-C4B3-3088-B6BC-569DDFCD8D77> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x7fffd3e5e000 -     0x7fffd3f4ffff  libJP2.dylib (1570.1) <6D268C9D-309B-3098-BBCF-8A1B98DBBEE9> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x7fffd3f50000 -     0x7fffd3f73fff  libJPEG.dylib (1570.1) <7EFA7A91-06C8-329E-AA3D-CF6DB2220A5A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x7fffd3f74000 -     0x7fffd3f9afff  libPng.dylib (1570.1) <AF8292B6-2564-30D4-8860-6B0C9D0E1405> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x7fffd3f9b000 -     0x7fffd3f9dff3  libRadiance.dylib (1570.1) <B0256EB7-7F87-39FD-BD35-83577F4FE7EC> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x7fffd3f9e000 -     0x7fffd3ff7fff  libTIFF.dylib (1570.1) <F1F0B7C6-388F-35E4-87CF-816CEE8B0E00> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x7fffd4117000 -     0x7fffd4bbdff7  com.apple.JavaScriptCore (12602 - 12602.1.50.0.5) <D701E578-C347-392D-BB90-1B144DAAAEEB> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
    0x7fffd4bbe000 -     0x7fffd4bd7ff7  com.apple.Kerberos (3.0 - 1) <49DCBE1A-130C-3FBF-AAEA-AF9A518913AC> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x7fffd4e51000 -     0x7fffd4e57fff  com.apple.MediaAccessibility (1.0 - 97.1.1) <EE1825C7-3B58-32F8-9F5F-B7172452BB01> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
    0x7fffd4e6d000 -     0x7fffd53bafff  com.apple.MediaToolbox (1.0 - 1903.7) <37363406-481C-3DDD-A61F-9E2153A3660B> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
    0x7fffd53bb000 -     0x7fffd5412ff7  com.apple.Metal (85.82 - 85.82) <CDC847A6-F1F6-3661-8981-180F2A485092> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
    0x7fffd5b28000 -     0x7fffd5b30fff  com.apple.NetFS (6.0 - 4.0) <6614F9B8-0861-338B-8FF0-8E402F96141C> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x7fffd5d04000 -     0x7fffd5d0cff7  libcldcpuengine.dylib (2.8.4) <F15C17F0-3342-36BD-A28E-7AC44B87BF8C> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
    0x7fffd5d0d000 -     0x7fffd5df3fff  unorm8_bgra.dylib (2.8.4) <387BD705-3EB5-3335-9F35-8C8E54B6A553> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib
    0x7fffd5ed5000 -     0x7fffd5f23ff3  com.apple.opencl (2.8.6 - 2.8.6) <DA3164B7-EB48-3F68-A40F-CD9B433E385F> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x7fffd5f24000 -     0x7fffd5f3dffb  com.apple.CFOpenDirectory (10.12 - 194) <BDD22B3E-4149-366A-A974-942280861DD4> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x7fffd5f3e000 -     0x7fffd5f49ff7  com.apple.OpenDirectory (10.12 - 194) <E1125140-E42C-369C-8DC8-D0935767B275> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
    0x7fffd5f4a000 -     0x7fffd5f4cfff  libCVMSPluginSupport.dylib (12.4.2.1) <5A7CBDC5-297E-30E0-8951-2F3DAFD0027E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
    0x7fffd5f4d000 -     0x7fffd5f50ff7  libCoreFSCache.dylib (148) <3297ACE0-B9D8-3821-8685-2619B4234621> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
    0x7fffd5f51000 -     0x7fffd5f54fff  libCoreVMClient.dylib (148) <B4299590-02BA-3130-98EA-A2D3A53852E1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
    0x7fffd5f55000 -     0x7fffd5f5dffb  libGFXShared.dylib (12.4.2.1) <3CBE90E5-6472-3C4C-825D-7567A5652115> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
    0x7fffd5f5e000 -     0x7fffd5f69fff  libGL.dylib (12.4.2.1) <E68C6C85-3B98-3525-9279-3296977FBF9F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x7fffd5f6a000 -     0x7fffd5fa6ff7  libGLImage.dylib (12.4.2.1) <50C7DE05-73CB-3D21-BB93-31C384EB6199> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x7fffd5fa7000 -     0x7fffd611dffb  libGLProgrammability.dylib (12.4.2.1) <2B17044B-CDB6-38F7-BA1F-9ED1A078481A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
    0x7fffd611e000 -     0x7fffd615eff3  libGLU.dylib (12.4.2.1) <D5DB68EC-751F-34D1-BCEB-2B86D560E243> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x7fffd6ac6000 -     0x7fffd6ad4fff  com.apple.opengl (12.4.2 - 12.4.2) <06F5BF0B-BD03-361D-9D7B-626517E4F761> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x7fffd6ad5000 -     0x7fffd6c7bfff  GLEngine (12.4.2.1) <8FFA4B17-F02A-3D7A-ACA9-D156E4E43B4D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
    0x7fffd6c7c000 -     0x7fffd6ca6ffb  GLRendererFloat (12.4.2.1) <82826589-22A1-312C-9C4E-FA45F4D8D976> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
    0x7fffd6d3d000 -     0x7fffd6e84ff7  com.apple.QTKit (7.7.3 - 2974) <DD63A171-2DE6-3210-89B0-BD5991539755> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
    0x7fffd6e85000 -     0x7fffd70f0fff  com.apple.imageKit (3.0 - 1016) <A3D24043-95CD-3A40-9850-83E02BDF56D0> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
    0x7fffd70f1000 -     0x7fffd71aaff7  com.apple.PDFKit (1.0 - 1) <32ED1D9C-B9AB-337B-93E5-9DDA8E68F6FB> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
    0x7fffd71ab000 -     0x7fffd76d1fff  com.apple.QuartzComposer (5.1 - 351) <10A260C7-A44C-3C64-BF68-FC0FCCD08489> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
    0x7fffd76d2000 -     0x7fffd76f5ffb  com.apple.quartzfilters (1.10.0 - 1.10.0) <9ECD9812-151A-300D-8F37-F7FEBE67B8BC> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
    0x7fffd76f6000 -     0x7fffd77e3ff7  com.apple.QuickLookUIFramework (5.0 - 720) <7DBE40A6-3F2F-3AF0-ACF4-8C95B78346C5> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
    0x7fffd77e4000 -     0x7fffd77e4fff  com.apple.quartzframework (1.5 - 21) <09455972-8A33-3D61-B193-BA7E7CF984CA> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
    0x7fffd77e5000 -     0x7fffd79dfff7  com.apple.QuartzCore (1.11 - 449.39) <B6BEEBAC-2923-3BA6-8DBD-621A2B0E51C1> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x7fffd79e0000 -     0x7fffd7a35ff7  com.apple.QuickLookFramework (5.0 - 720) <F54FCBB5-53DD-351D-AAEB-2470CEB30017> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
    0x7fffd7a36000 -     0x7fffd7a49ff7  com.apple.SafariServices.framework (12602 - 12602.1.50.0.8) <6FCD4088-A455-3212-BE94-96881C167763> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
    0x7fffd7f45000 -     0x7fffd8260fff  com.apple.security (7.0 - 57740.1.18) <AF5E42F1-B513-3410-A5BE-1EC9CBAF8452> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x7fffd8261000 -     0x7fffd82d7ff7  com.apple.securityfoundation (6.0 - 55132.1.1) <259D4B70-0F8C-3818-99E7-3EBEAA18DE1B> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
    0x7fffd8301000 -     0x7fffd8304ff3  com.apple.xpc.ServiceManagement (1.0 - 1) <6A9EA339-BB6A-3DD9-BF08-00B8C0262839> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
    0x7fffd8689000 -     0x7fffd86faff7  com.apple.SystemConfiguration (1.14 - 1.14) <C7F21776-2CCE-327B-B155-7A5948277BD6> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x7fffd86fb000 -     0x7fffd8aa6ff7  com.apple.VideoToolbox (1.0 - 1903.7) <C0044876-9800-3CCA-B7D3-50B92077EF4D> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
    0x7fffdad08000 -     0x7fffdad23ff3  com.apple.AppContainer (4.0 - 307.1.1) <05373DD5-5892-3542-B178-C140F1AB6886> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
    0x7fffdad24000 -     0x7fffdad31ff3  com.apple.AppSandbox (4.0 - 307.1.1) <20324EFC-70DC-389D-9C27-37DCAA7E07CC> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
    0x7fffdad32000 -     0x7fffdad54ffb  com.apple.framework.Apple80211 (12.0 - 1200.33) <06F8EA45-5E43-3744-BF41-BA86B8BBB5CF> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
    0x7fffdad55000 -     0x7fffdad64fdb  com.apple.AppleFSCompression (88 - 1.0) <B6E2148F-BFBF-3F1B-A7DF-0F39190B4C20> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
    0x7fffdae4c000 -     0x7fffdaed797f  com.apple.AppleJPEG (1.0 - 1) <B4C3209B-58A5-359F-A898-F61B6C40E5E9> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
    0x7fffdaf10000 -     0x7fffdaf13ff3  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <6FF50E26-5BDA-3421-BDAE-B57AE6E4F6AC> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
    0x7fffdaf14000 -     0x7fffdaf66fff  com.apple.AppleVAFramework (5.0.34 - 5.0.34) <193400A6-B326-3911-BB4F-6C49C1E5FA8F> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
    0x7fffdaf6f000 -     0x7fffdaf76ffb  com.apple.AssetCacheServices (31 - 31) <13E874CA-86AB-33E7-A4D8-544D3B8157CD> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServices
    0x7fffdb2f3000 -     0x7fffdb371ff7  com.apple.backup.framework (1.8 - 1.8) <65907BC4-B50A-3F2F-9A97-2DA0BD12F87E> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
    0x7fffdbf8b000 -     0x7fffdbfb2ffb  com.apple.ChunkingLibrary (172 - 172) <83E91936-305D-32A4-A256-5582B96B1852> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
    0x7fffdbfb3000 -     0x7fffdc045ffb  com.apple.CloudDocs (1.0 - 483.2) <9DBD244F-83A0-3593-AA84-313CD5861F2C> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
    0x7fffdc8d2000 -     0x7fffdc8dbffb  com.apple.CommonAuth (4.0 - 2.0) <D9958C57-9E97-33F5-A21C-B454FDB11548> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
    0x7fffdca5c000 -     0x7fffdce39fe7  com.apple.CoreAUC (224.0.0 - 224.0.0) <8DF6075A-0711-33A9-9031-6FDA22E85C4F> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
    0x7fffdce3a000 -     0x7fffdce6afff  com.apple.CoreAVCHD (5.9.0 - 5900.4.1) <5E1B0512-E50B-3534-99EF-AD15E601877A> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
    0x7fffdcff7000 -     0x7fffdd008fff  com.apple.CoreEmoji (1.0 - 40) <F3D73BF8-6D48-3B1F-BBE6-EE927E725E92> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
    0x7fffdd0bd000 -     0x7fffdd0d3fff  com.apple.CoreMediaAuthoring (2.2 - 955) <3B877988-3823-3A84-A083-CE0B5B54F791> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
    0x7fffdd0da000 -     0x7fffdd16affb  com.apple.CorePDF (4.0 - 4) <42FD0781-A19C-3E36-BFDA-DAEAFB3A3115> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
    0x7fffdd2e1000 -     0x7fffdd311ff3  com.apple.CoreServicesInternal (276 - 276) <CCB21255-89DC-3F53-A6D6-8FA8F693C837> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
    0x7fffdd59a000 -     0x7fffdd624fff  com.apple.CoreSymbolication (61050) <BAC8D20F-4DC6-32EE-91FE-BF08E930420A> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
    0x7fffdd625000 -     0x7fffdd75ffef  com.apple.coreui (2.1 - 424.1) <B9B92DB5-1C6C-306F-BD29-B1F82EC95283> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x7fffdd760000 -     0x7fffdd7ffffb  com.apple.CoreUtils (4.3 - 430.70) <87BEB880-3D71-3251-B51E-FF0A42DFC065> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
    0x7fffdd84f000 -     0x7fffdd8b4ff3  com.apple.framework.CoreWiFi (12.0 - 1200.25.1) <D7C870BE-55DE-34AF-8941-D42696D505B1> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
    0x7fffdd8b5000 -     0x7fffdd8c0fff  com.apple.CrashReporterSupport (10.12 - 815) <10C3797E-DD63-303B-B901-1C52A502D2F8> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
    0x7fffdd966000 -     0x7fffdd9ddff3  com.apple.datadetectorscore (7.0 - 539) <C3F6F52B-A1AD-36FA-9BF9-C8D0E147F0A3> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
    0x7fffdda17000 -     0x7fffdda56fff  com.apple.DebugSymbols (137 - 137) <B229F3F7-250B-3151-8048-CEA7BF80FA52> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
    0x7fffdda57000 -     0x7fffddb68ff7  com.apple.desktopservices (1.11 - 1.11) <494E239D-706F-350B-9481-2A8ECEEDBD8B> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x7fffddca7000 -     0x7fffddcb1fff  com.apple.DisplayServicesFW (3.1 - 380) <79733A44-F60D-3EC0-BBC7-C4AEC5649D8F> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
    0x7fffdde33000 -     0x7fffde264ff7  com.apple.vision.FaceCore (3.3.2 - 3.3.2) <DEB42099-6927-332C-8D3E-D45096318D25> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
    0x7fffdf59d000 -     0x7fffdf59dfff  libmetal_timestamp.dylib (600.0.48.25) <348D32E6-AD49-36DC-A0DE-5A44B2699FFA> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
    0x7fffdf5aa000 -     0x7fffdf5b5ff3  libGPUSupportMercury.dylib (12.4.2.1) <A720545E-40F3-3FE0-A8B3-067D49083417> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
    0x7fffdf867000 -     0x7fffdf883ff7  com.apple.GenerationalStorage (2.0 - 259) <43D40063-BD46-3008-8992-FF092B7C9A58> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
    0x7fffdf89b000 -     0x7fffdff2ffff  com.apple.GeoServices (1.0 - 1226.20.7.17.11) <A6007FBD-25F7-3F52-972A-EEFCE0F6BF70> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
    0x7fffdff75000 -     0x7fffdffebfff  com.apple.Heimdal (4.0 - 2.0) <18C127D7-9C61-3C5B-8C6F-7953760D2674> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
    0x7fffe05fd000 -     0x7fffe0604ffb  com.apple.IOAccelerator (288.13 - 288.13) <F77E27C3-20DD-3CE5-9D0A-6C89A997080E> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
    0x7fffe0606000 -     0x7fffe061aff3  com.apple.IOPresentment (1.0 - 25) <40934217-996A-3DDB-A8C4-484CA0F0222B> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
    0x7fffe061b000 -     0x7fffe063dff7  com.apple.IconServices (74.1 - 74.1) <F7B83970-4A72-3186-BBB3-90FA86C3E263> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
    0x7fffe06d8000 -     0x7fffe06e8ff3  com.apple.IntlPreferences (2.0 - 216) <43FFAB0C-4124-3231-B0CB-137CCB0A53AF> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
    0x7fffe071f000 -     0x7fffe08d3fff  com.apple.LanguageModeling (1.0 - 123) <10152D7F-C7C0-34AA-A295-D712D16C76E6> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
    0x7fffe09a3000 -     0x7fffe0a74ff3  com.apple.MMCS (1.3 - 379) <14867D2F-6E87-351E-AB4B-9BD759364DFD> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
    0x7fffe0f0a000 -     0x7fffe0f0dfff  com.apple.Mangrove (1.0 - 1) <05039E9F-9C07-375B-A940-D90D455A2EC2> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
    0x7fffe1169000 -     0x7fffe11e1fef  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <FAFA0DF5-4226-3867-A2E2-CAB889DC4490> /System/Library/PrivateFrameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
    0x7fffe1347000 -     0x7fffe1352ff7  com.apple.MobileKeyBag (2.0 - 1.0) <7ECC9D0A-246F-3D7E-9E78-16DBA0B55F49> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
    0x7fffe1363000 -     0x7fffe1389fff  com.apple.MultitouchSupport.framework (367.6 - 367.6) <32D8588A-29BD-3A23-92B2-05C013DA5BC5> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
    0x7fffe1436000 -     0x7fffe1440fff  com.apple.NetAuth (6.0 - 6.0) <D57D5888-0290-3295-A1C4-D673D4DCB497> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
    0x7fffe1be1000 -     0x7fffe1c22ff7  com.apple.PerformanceAnalysis (1.145 - 145) <9DF1FCCC-7EBF-3213-B77A-0C3D3B7CF7AF> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
    0x7fffe2286000 -     0x7fffe22b1ffb  com.apple.ProtectedCloudStorage (1.0 - 1) <A1219818-97B0-3A4D-825B-24ADF9B7C8B6> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
    0x7fffe22b2000 -     0x7fffe22ccfff  com.apple.ProtocolBuffer (1 - 249) <D8B7694B-B598-3728-8583-9C4CC0F05B64> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
    0x7fffe22cd000 -     0x7fffe22ddffb  com.apple.QuickLookThumbnailing (1.0 - 1) <DD5F14E6-A8A8-3EA8-96A3-4C84092BC18F> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThumbnailing
    0x7fffe22e6000 -     0x7fffe2309ff3  com.apple.RemoteViewServices (2.0 - 124) <280DB828-4613-3DF8-ACBA-C91989B64347> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
    0x7fffe2f38000 -     0x7fffe2f3bff7  com.apple.SecCodeWrapper (4.0 - 307.1.1) <64F951CB-A975-32F0-BC60-1E839E607FCB> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
    0x7fffe2fc9000 -     0x7fffe3044fff  com.apple.Sharing (659.1.6 - 659.1.6) <C217107C-CD4B-311D-9FBA-7435B1F6186F> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
    0x7fffe3065000 -     0x7fffe32c6ff3  com.apple.SkyLight (1.600.0 - 100) <F0B08B4C-8550-3241-8128-F7601E60BDEB> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
    0x7fffe34a0000 -     0x7fffe34acfff  com.apple.SpeechRecognitionCore (3.0.15 - 3.0.15) <BE386037-4B61-341F-80E2-5D8B5B50C8BC> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
    0x7fffe3b8f000 -     0x7fffe3bfbff3  com.apple.Symbolication (61080.2) <0F183B36-0BCF-3330-8C68-4A521A142919> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
    0x7fffe3ff2000 -     0x7fffe3ff8ff7  com.apple.TCC (1.0 - 1) <CEE9F9F9-2A24-3F60-BE73-4703D85E307C> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
    0x7fffe4084000 -     0x7fffe4237ff3  com.apple.TextureIO (1.31 - 1.31) <9E6E91C7-76DC-3C12-9629-494084792476> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
    0x7fffe42ab000 -     0x7fffe42acfff  com.apple.TrustEvaluationAgent (2.0 - 28) <6793B664-C4FC-3CD4-B0E7-25B9933391AC> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
    0x7fffe42ad000 -     0x7fffe443cffb  com.apple.UIFoundation (1.0 - 489) <0CD14719-FC52-3AC5-87EF-775437927990> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
    0x7fffe4e97000 -     0x7fffe4f46ff7  com.apple.ViewBridge (265.1 - 265.1) <21855FE3-F19D-3E3F-9500-BFC811DA75C6> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
    0x7fffe536e000 -     0x7fffe5374fff  com.apple.XPCService (2.0 - 1) <BC3FCE26-6219-3316-949F-37F7005C9A0F> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
    0x7fffe5445000 -     0x7fffe5447ffb  com.apple.loginsupport (1.0 - 1) <03B57D6F-C210-32BC-B384-5B0E95660283> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
    0x7fffe549c000 -     0x7fffe54b7ff7  libCRFSuite.dylib (34) <BACC371B-6153-36B5-BC54-3BCF26FBB221> /usr/lib/libCRFSuite.dylib
    0x7fffe54b8000 -     0x7fffe54c3fff  libChineseTokenizer.dylib (21) <09E74E18-ADB2-30D2-A858-13691CB1186C> /usr/lib/libChineseTokenizer.dylib
    0x7fffe5555000 -     0x7fffe5556ff3  libDiagnosticMessagesClient.dylib (102) <422911A4-E273-3E88-BFC4-DF6470E48242> /usr/lib/libDiagnosticMessagesClient.dylib
    0x7fffe5557000 -     0x7fffe576afff  libFosl_dynamic.dylib (16.37) <3EA1C7EE-4A6C-3B09-BCA7-81A074B24013> /usr/lib/libFosl_dynamic.dylib
    0x7fffe5786000 -     0x7fffe578dfff  libMatch.1.dylib (27) <5D52A207-E2AF-3E05-8C51-91C1D82FCEE8> /usr/lib/libMatch.1.dylib
    0x7fffe578e000 -     0x7fffe578efff  libOpenScriptingUtil.dylib (172) <D025E180-BB3B-3FFA-98FC-B6835354D723> /usr/lib/libOpenScriptingUtil.dylib
    0x7fffe578f000 -     0x7fffe5792ff7  libScreenReader.dylib (477.1.5) <88D484EC-7589-324B-890D-799F27DF0FB3> /usr/lib/libScreenReader.dylib
    0x7fffe5793000 -     0x7fffe5794ff3  libSystem.B.dylib (1238) <168B3C56-081B-3998-9A44-681EB4C6828F> /usr/lib/libSystem.B.dylib
    0x7fffe5800000 -     0x7fffe582bffb  libarchive.2.dylib (41.1.1) <C4F76D18-8484-3779-AE80-14F27E57ABB5> /usr/lib/libarchive.2.dylib
    0x7fffe582c000 -     0x7fffe5906fe7  libate.dylib (1.12.12) <1371D20C-3A80-37A5-AB94-09C4C4F67B01> /usr/lib/libate.dylib
    0x7fffe590a000 -     0x7fffe590aff3  libauto.dylib (187) <5BBF6A00-CC76-389D-84E7-CA88EDADE683> /usr/lib/libauto.dylib
    0x7fffe590b000 -     0x7fffe591bff3  libbsm.0.dylib (34) <20084796-B04D-3B35-A003-EA11459557A9> /usr/lib/libbsm.0.dylib
    0x7fffe591c000 -     0x7fffe592aff7  libbz2.1.0.dylib (38) <6FD3B63F-0F86-3A25-BD5B-E243F58792C9> /usr/lib/libbz2.1.0.dylib
    0x7fffe592b000 -     0x7fffe5981ff7  libc++.1.dylib (307.4) <BEE86868-F831-384C-919E-2B286ACFE87C> /usr/lib/libc++.1.dylib
    0x7fffe5982000 -     0x7fffe59acfff  libc++abi.dylib (307.2) <1CEF8ABB-7E6D-3C2F-8E0A-E7884478DD23> /usr/lib/libc++abi.dylib
    0x7fffe59ad000 -     0x7fffe59bdffb  libcmph.dylib (6) <2B5D405E-2D0B-3320-ABD6-622934C86ABE> /usr/lib/libcmph.dylib
    0x7fffe59be000 -     0x7fffe59d3ffb  libcompression.dylib (34) <AEF908E6-C0FE-3884-BD45-FB37A035545D> /usr/lib/libcompression.dylib
    0x7fffe59d4000 -     0x7fffe59d4ff7  libcoretls.dylib (121.1.1) <F3BAB54C-DA82-37C3-A218-46FEB179D555> /usr/lib/libcoretls.dylib
    0x7fffe59d5000 -     0x7fffe59d6ffb  libcoretls_cfhelpers.dylib (121.1.1) <D12709F3-BBE3-3CF7-9070-C2A0803F5526> /usr/lib/libcoretls_cfhelpers.dylib
    0x7fffe5a90000 -     0x7fffe5b74ff3  libcrypto.0.9.8.dylib (64) <4CB423CE-0B86-334A-9335-FEE75198024F> /usr/lib/libcrypto.0.9.8.dylib
    0x7fffe5d12000 -     0x7fffe5d65ff7  libcups.2.dylib (450) <04CA1F55-4B70-3D65-B4B1-62F6C271A9EF> /usr/lib/libcups.2.dylib
    0x7fffe5db6000 -     0x7fffe5dbdff3  libdscsym.dylib (145) <0972B577-B427-3A1C-A9E7-325B6B265135> /usr/lib/libdscsym.dylib
    0x7fffe5ddf000 -     0x7fffe5ddffff  libenergytrace.dylib (15) <A1B040A2-7977-3097-9ADF-34FF181EB970> /usr/lib/libenergytrace.dylib
    0x7fffe5def000 -     0x7fffe5df4ff3  libheimdal-asn1.dylib (498) <8F3F1AE8-CE4A-355C-82E3-74DA46B5BB02> /usr/lib/libheimdal-asn1.dylib
    0x7fffe5df5000 -     0x7fffe5ee7ff7  libiconv.2.dylib (50) <42125B35-81D7-3FC4-9475-A26DBE10884D> /usr/lib/libiconv.2.dylib
    0x7fffe5ee8000 -     0x7fffe610dfff  libicucore.A.dylib (57131.0.1) <72594943-D25E-3F70-A4AC-8E9F9F442B7E> /usr/lib/libicucore.A.dylib
    0x7fffe6113000 -     0x7fffe6114fff  liblangid.dylib (126) <3F4530C9-8BE1-3AA7-9A82-98694D240866> /usr/lib/liblangid.dylib
    0x7fffe6115000 -     0x7fffe612effb  liblzma.5.dylib (10) <44BD0279-99DD-36B5-8A6E-C11432E2098D> /usr/lib/liblzma.5.dylib
    0x7fffe612f000 -     0x7fffe6145ff7  libmarisa.dylib (5) <2183D484-032D-3DE5-8984-3A14006E034E> /usr/lib/libmarisa.dylib
    0x7fffe6146000 -     0x7fffe63effff  libmecabra.dylib (744) <545EDC2D-22BB-3E8F-BFD3-921447581D9F> /usr/lib/libmecabra.dylib
    0x7fffe6422000 -     0x7fffe649affb  libnetwork.dylib (856.1.8) <30FC3C60-CCA9-3E2B-80AA-DE53F5762374> /usr/lib/libnetwork.dylib
    0x7fffe649b000 -     0x7fffe6870127  libobjc.A.dylib (706) <47104A1B-13E8-369F-BC36-27FF465809FD> /usr/lib/libobjc.A.dylib
    0x7fffe6873000 -     0x7fffe6877fff  libpam.2.dylib (21) <352F8FF6-2248-3594-B357-8D031DEFB06C> /usr/lib/libpam.2.dylib
    0x7fffe6878000 -     0x7fffe68a8ff7  libpcap.A.dylib (67) <450DB888-2C0C-3085-A5F1-69324DFE902C> /usr/lib/libpcap.A.dylib
    0x7fffe68c6000 -     0x7fffe68e2ffb  libresolv.9.dylib (64) <A244AE4C-00B0-396C-98FF-97FE4DB3DA30> /usr/lib/libresolv.9.dylib
    0x7fffe68e3000 -     0x7fffe691cfff  libsandbox.1.dylib (592.1.3) <0024D751-23D8-35DF-87CF-72E489DA2F9F> /usr/lib/libsandbox.1.dylib
    0x7fffe6930000 -     0x7fffe6931ff3  libspindump.dylib (228) <F80FAB75-D656-3FDA-8753-D3D6771B17E6> /usr/lib/libspindump.dylib
    0x7fffe6932000 -     0x7fffe6a73ffb  libsqlite3.dylib (252) <A531C105-64D7-37C0-B999-9320047B71C5> /usr/lib/libsqlite3.dylib
    0x7fffe6acf000 -     0x7fffe6b1ffff  libstdc++.6.dylib (104.1) <91F66BFD-F927-301F-B8F3-578A5CEA78F4> /usr/lib/libstdc++.6.dylib
    0x7fffe6b64000 -     0x7fffe6b71fff  libxar.1.dylib (354) <AAFCF321-8100-3622-880B-9661DCA35D69> /usr/lib/libxar.1.dylib
    0x7fffe6b75000 -     0x7fffe6c64ffb  libxml2.2.dylib (30.11) <26676155-64CE-323F-B73C-AD77AF5982E8> /usr/lib/libxml2.2.dylib
    0x7fffe6c65000 -     0x7fffe6c8efff  libxslt.1.dylib (15.8) <FFF5DD45-F544-34B2-BE3C-DB877DC60081> /usr/lib/libxslt.1.dylib
    0x7fffe6c8f000 -     0x7fffe6ca0ff3  libz.1.dylib (67) <46E3FFA2-4328-327A-8D34-A03E20BFFB8E> /usr/lib/libz.1.dylib
    0x7fffe6caf000 -     0x7fffe6cb3ff7  libcache.dylib (79) <84E55656-FDA9-3B29-9E4F-BE31B2C0AA3C> /usr/lib/system/libcache.dylib
    0x7fffe6cb4000 -     0x7fffe6cbefff  libcommonCrypto.dylib (60092.1.2) <79F738D8-0AD7-3DEA-AF80-E0F8B90B74E3> /usr/lib/system/libcommonCrypto.dylib
    0x7fffe6cbf000 -     0x7fffe6cc6fff  libcompiler_rt.dylib (62) <486BDE52-81B4-3446-BD72-23977CAE556F> /usr/lib/system/libcompiler_rt.dylib
    0x7fffe6cc7000 -     0x7fffe6ccffff  libcopyfile.dylib (138) <0DA49B77-56EC-362D-98FF-FA78CFD986D6> /usr/lib/system/libcopyfile.dylib
    0x7fffe6cd0000 -     0x7fffe6d52ff3  libcorecrypto.dylib (442.1.3) <1CA8B679-810E-3C04-945A-4AC19372CDC7> /usr/lib/system/libcorecrypto.dylib
    0x7fffe6d53000 -     0x7fffe6d85fff  libdispatch.dylib (703.1.4) <12B1D95B-283D-325D-85AB-29A2FFD36987> /usr/lib/system/libdispatch.dylib
    0x7fffe6d86000 -     0x7fffe6d8bff3  libdyld.dylib (421.1) <CDFBDC9C-418C-369D-B433-F64B0630E640> /usr/lib/system/libdyld.dylib
    0x7fffe6d8c000 -     0x7fffe6d8cffb  libkeymgr.dylib (28) <09CD7CA6-46D2-3A9F-B9F1-7C4CA5CA0D68> /usr/lib/system/libkeymgr.dylib
    0x7fffe6d8d000 -     0x7fffe6d99ffb  libkxld.dylib (3789.1.32) <48BDBE7F-AAE6-3050-9017-6959051CF16A> /usr/lib/system/libkxld.dylib
    0x7fffe6d9a000 -     0x7fffe6d9afff  liblaunch.dylib (972.1.5) <DC31FDEA-FD81-335E-BAA8-5A7395D20772> /usr/lib/system/liblaunch.dylib
    0x7fffe6d9b000 -     0x7fffe6da0fff  libmacho.dylib (894) <1EAE5ADD-490C-3B1F-9F97-447BA8E0E90F> /usr/lib/system/libmacho.dylib
    0x7fffe6da1000 -     0x7fffe6da3ff3  libquarantine.dylib (85) <78EF62D8-C890-3FC0-937A-C2FD8CEF8992> /usr/lib/system/libquarantine.dylib
    0x7fffe6da4000 -     0x7fffe6da5ffb  libremovefile.dylib (45) <C4FC07FF-ED86-382E-B06F-33C34718080C> /usr/lib/system/libremovefile.dylib
    0x7fffe6da6000 -     0x7fffe6dbeff7  libsystem_asl.dylib (349.1.1) <F0987490-8427-367F-B302-A05A7D61FEBF> /usr/lib/system/libsystem_asl.dylib
    0x7fffe6dbf000 -     0x7fffe6dbfff7  libsystem_blocks.dylib (67) <B8C3701D-5A91-3D35-999D-2DC8D5393525> /usr/lib/system/libsystem_blocks.dylib
    0x7fffe6dc0000 -     0x7fffe6e4dfe7  libsystem_c.dylib (1158.1.2) <5F260836-48E4-3F57-8553-62D2DA228A1F> /usr/lib/system/libsystem_c.dylib
    0x7fffe6e4e000 -     0x7fffe6e51ffb  libsystem_configuration.dylib (888.1.2) <67BB9D8B-2430-38AD-81A7-F0EC924B2590> /usr/lib/system/libsystem_configuration.dylib
    0x7fffe6e52000 -     0x7fffe6e55fff  libsystem_coreservices.dylib (41.1) <11F22E6C-0DCB-3699-A4F0-C99E301E56E9> /usr/lib/system/libsystem_coreservices.dylib
    0x7fffe6e56000 -     0x7fffe6e6effb  libsystem_coretls.dylib (121.1.1) <8F7E9B12-400D-3276-A9C5-4546B0258554> /usr/lib/system/libsystem_coretls.dylib
    0x7fffe6e6f000 -     0x7fffe6e75fff  libsystem_dnssd.dylib (765.1.2) <C5FF2025-C60B-39C6-B205-6BF1BC51D1B3> /usr/lib/system/libsystem_dnssd.dylib
    0x7fffe6e76000 -     0x7fffe6e9ffff  libsystem_info.dylib (503) <C686B834-5E7D-382C-AF6E-44AB78EE83E2> /usr/lib/system/libsystem_info.dylib
    0x7fffe6ea0000 -     0x7fffe6ec2ff7  libsystem_kernel.dylib (3789.1.32) <5C68A0D7-C3C9-3E52-B983-EDE9A28AB6FC> /usr/lib/system/libsystem_kernel.dylib
    0x7fffe6ec3000 -     0x7fffe6f0afe7  libsystem_m.dylib (3121.4) <E3370D16-EBAA-3C7F-AC56-2D6EAD7DB0A4> /usr/lib/system/libsystem_m.dylib
    0x7fffe6f0b000 -     0x7fffe6f29ff7  libsystem_malloc.dylib (116) <3DD17B88-B7A4-38B9-9E95-AB88E1C3B647> /usr/lib/system/libsystem_malloc.dylib
    0x7fffe6f2a000 -     0x7fffe6f80fff  libsystem_network.dylib (856.1.8) <A8973360-956A-33BF-9971-14D59C84E0D1> /usr/lib/system/libsystem_network.dylib
    0x7fffe6f81000 -     0x7fffe6f8aff3  libsystem_networkextension.dylib (563.1.11) <1C551832-9360-36DD-A7BA-52B55A171720> /usr/lib/system/libsystem_networkextension.dylib
    0x7fffe6f8b000 -     0x7fffe6f94ffb  libsystem_notify.dylib (165) <AF77D471-6B13-36BA-B144-7E7DDB9DBA9F> /usr/lib/system/libsystem_notify.dylib
    0x7fffe6f95000 -     0x7fffe6f9dfe7  libsystem_platform.dylib (126.1.2) <884DDF42-3CAE-334A-82CE-965617130FB1> /usr/lib/system/libsystem_platform.dylib
    0x7fffe6f9e000 -     0x7fffe6fa8fff  libsystem_pthread.dylib (218.1.3) <050AE77B-4F4B-334A-A5BA-CF0D10AF5304> /usr/lib/system/libsystem_pthread.dylib
    0x7fffe6fa9000 -     0x7fffe6facfff  libsystem_sandbox.dylib (592.1.3) <90FEF628-316D-3F84-9EF4-F7F510A4FBBB> /usr/lib/system/libsystem_sandbox.dylib
    0x7fffe6fad000 -     0x7fffe6faefff  libsystem_secinit.dylib (24) <A54B8FEF-E792-3C54-8E0B-E80A376662F2> /usr/lib/system/libsystem_secinit.dylib
    0x7fffe6faf000 -     0x7fffe6fb6fff  libsystem_symptoms.dylib (532.1.1) <B26F656E-94F9-3834-9B03-51C4FF11D1BF> /usr/lib/system/libsystem_symptoms.dylib
    0x7fffe6fb7000 -     0x7fffe6fd7ff7  libsystem_trace.dylib (518.1.16) <C3CDF7BC-CA3D-34F5-ADF8-46AAAB0B47F8> /usr/lib/system/libsystem_trace.dylib
    0x7fffe6fd8000 -     0x7fffe6fddffb  libunwind.dylib (35.3) <9F7C2AD8-A9A7-3DE4-828D-B0F0F166AAA0> /usr/lib/system/libunwind.dylib
    0x7fffe6fde000 -     0x7fffe7007ff7  libxpc.dylib (972.1.5) <2A901937-48E1-3BF2-83F1-2431156D82B7> /usr/lib/system/libxpc.dylib
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 100094
    thread_create: 0
    thread_set_state: 6998
VM Region Summary:
ReadOnly portion of Libraries: Total=359.9M resident=0K(0%) swapped_out_or_unallocated=359.9M(100%)
Writable regions: Total=255.1M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=255.1M(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
Accelerate framework               384K        3
Activity Tracing                   256K        2
CG backing stores                 24.3M        9
CG image                           344K       23
CoreAnimation                      528K       18
CoreAnimation (reserved)             4K        2         reserved VM address space (unallocated)
CoreUI image data                 2712K       20
CoreUI image file                  156K        4
Foundation                           4K        2
Image IO                            28K        4
Kernel Alloc Once                    8K        2
MALLOC                           192.3M       65
MALLOC guard page                   64K       13
Memory Tag 242                      12K        2
Memory Tag 249                     156K        2
OpenCL                              16K        3
SQLite page cache                   64K        2
STACK GUARD                       56.1M       21
Stack                             17.6M       21
VM_ALLOCATE                        196K       34
VM_ALLOCATE (reserved)             256K        2         reserved VM address space (unallocated)
__DATA                            40.4M      302
__GLSLBUILTINS                    2588K        2
__IMAGE                            528K        2
__LINKEDIT                       118.5M       62
__TEXT                           241.8M      298
__UNICODE                          556K        2
mapped file                       61.0M       37
shared memory                     16.4M       18
TOTAL                            777.0M      948
TOTAL, minus reserved VM space   776.7M      948
Sorry for the trouble guys! The issue has been resolved and an update with the fixes has already been submitted to the App Store and will be available within few days. Till then please bear with us.
Cheers!
Hi, the app crashes on the new macOS Sierra after creating a login item and adding that item to a folder. Appreciate your help on a fix, thanks.
Edited by fabpopa
Hey guys,
Today only we have released the update as v5.3.1, so please update from Mac App store to get rid of these crashing issues.
Cheers!
Thanks @Anshu kumar,
Everything seems to be working great so far this morning.
Just a quick question, are you guys planning on developing an extension for the Safari Technical Preview, I can't seem to get it to work with it...?
Thanks again,
Scott
Hi @scottrych,
Thanks for writing in and sorry for late reply.
Yes, we are and would be available in next update. If you can't wait for the next update, you can make Enpass extension work with Safari Technical Preview by turning off the Code signature verification in main Enpass App as explained here in user manual although its not a safe practice.
To avoid any security risks associated with turning off the code signature verification, please make sure that you download the browser from the legitimate source and double check the authenticity of any extension you install.
