Menubar icon is acting up on multi-monitor setup
Hi all,
The issue is very simple. I use one external display connected to my Mac and the menubar icon on currently inactive display shrinks vertically. Basically it looks like this: https://prnt.sc/yw5qnt
Thanks.
Hey @Egor K
We regret the problem you are facing. Our team is already aware of this issue with multi-monitor and are looking into this towards a fix.
Thanks!
  • 5 months later...
On 2/11/2021 at 7:25 AM, Garima Singh said:
Hey @Egor K
Thanks!
Hi @Garima Singh
Is there any update on this? It of course doesn't affect the functionality of the program, it's just annoying :)
Thanks!
  • 4 weeks later...
Hi @Discordant,
Thank you for providing the link. We are in process to upgrade Enpass Qt framework to 6.2 by end of the year. Many long pending UI bugs will be addressed in that update.
  • 5 months later...
Hi there, any updates on this ? Thank you a lot.
Hi @d1abo,
Thanks for reaching out to us.
I realize that these minor glitches are annoying to the eye, but I want to assure you that this issue will be fixed in the upcoming release of Enpass. I will notify you as soon as possible if there are any updates regarding the ETA for the update. In the meantime, we appreciate your patience.
#SI-2473
  • 3 months later...
  • 2 months later...
Hello everyone, it seems fixed on my side. Did you do anything ? Thanks a lot !
  • 2 months later...
Can confirm it is fixed on Mac OS 12.4. Thanks a lot !
