February 15, 20215 yr I updated my Win32 Enpass version to version 6.6.0 (775) today. The update went through without any problems, but Enpass does not start anymore. I uninstalled Enpass, deleted all Regedit entries, reinstalled Enpass - the error remains. Enpass is not even listed in the task manager. What am I doing wrong? Do you have a solution for me?
February 22, 20215 yr Author I have since switched to the Windows 10 Store version of Enpass. It works at least
February 24, 20215 yr Hey @gnrmarcel & @qwertyops Apologies for the trouble. Please confirm if you have updated your system recently after which you are facing this problem? Also, please make sure your device is up to date and try to launch app using Run as Administrator and share your findings with us. If this doesn't help, let us know which OS version you are using currently. Thanks!
February 26, 20215 yr My issue may or may not be related, but after the 6.6.0 (750) update I cannot see my data unless I manually go into edit-mode of each entry. Also I cannot create new entries in Windows anymore as nothing shows up after I choose "New Entry" from the create new entry workflow. Tried uninstalling and installing the Windows Appstore version and the same issue persists after dropbox sync of database.
February 26, 20215 yr Hey @Reiska That's strange. Please check if you have reduced or minimized the main window of the Enpass app. If yes, please extend the window size on your Windows device and let us know if the issue is still there along with the device OS on which you are having this issue and the snapshot of the error page/screen?
