February 16, 20215 yr I have been using roboform since last 12 years and i have over 2k+ passwords. I successfully imported my passwords from roboform to Enpass but when i imported my roboform notes to Enpass i got a problem. All notes were imported successfully but enpass did not import all data of notes. Many of them had titles only but no data in notes. I tried exporting and importing CSV also but issue remained. Now i have doubts about logins also and i will have to manually go through all logins to make sure it has imported all if my logins. Second issue i had was. I have websites which have multiple fields more then just Login or password. some have 3 fields some have 4 fields and i never had any issue filling them with roboform but with Enpass even that field is available in Enpass in custom fields Enpass did not filled those fields and i had to manually copy paste that field from Enpass. Is there anyone who can help me importing my exported notes from Roboform to Enpass? I have Enpass lifetime premium but now if these issues do not get resolved i will have to move back to roboform sadly. Just found another issue after posting here i tried to manually copy paste my notes into enpass while i was working on that i tried to paste a note from roboform to enpass which has over 500 lines of bitcoin paper wallets but when i pasted it into enpass it stored 100 lines of those and rest of 400 lines were not copied. I have premium subscription and i am using my own onedrive then why there is limit on this? is there any setting we can remove this limit? Edited February 16, 20215 yr by Fadi
February 18, 20215 yr Hi @Fadi, Sorry for the inconvenience caused to you. Please share the following details so that we can investigate where the problem could be. Version of Roboform and it's default language? Version of Enpass you are using? The device and OS on which you are trying to import? Can you please share the website where you are having the problem so that we can check at our end? Thanks for your co-operation.
February 26, 20215 yr Author @Pratyush Sharma Roboform Version 9.1.1.1 Enpass Version 6.6.0 (775) OS: Windows 10 Pro OS Version: 20H2 OS Build: 19042.804 Due to security concerns i am not able to share those websites publicly so i have sent you message in inbox for samle website URL which have more then 2 login fields.
March 1, 20215 yr Hi @Fadi, Thanks for sharing the details. I have noted down this issue and notified the team to look into it.
March 3, 20215 yr Hi @Fadi, I have received an update from the team that we've been able to reproduce the issue on our system. Thanks for reporting this.
April 15, 20215 yr Author I hope this issue is resolved and new update is pushed as i am waiting to move to enpass.
April 15, 20215 yr Hey @Fadi Thanks for the patience. I would like to share that the this issue has been fixed in the upcoming beta version (v6.6.2) and the same will be releasing soon.
