I am not sure if I am using 2FA right
When I login to a website with 2FA, Enpass enters the username/password. Then I am prompted for a 6-digit code. Enpass does not autofill this code. I go back to Enpass, look up the account, copy the code and then go back to Safari to enter the code.
Is this the official way of doing this? I think it would be easier if Enpass autofills the 6-digit code. Or am I missing something?
Hey @lexvo
Thanks for writing in.
Could you please check if you have enabled 'Auto-copy OTP' from Enpass Auto-fill settings on your iOS device. If the same is enabled, Enpass will auto copy the OTP after filling the login details; which sometimes gets auto-copied and we can auto-fill it by paste it.
2 hours ago, Garima Singh said:
Hey @lexvo
Thank you! I now understand that filling in the OTP works via the clipboard. It is all working now.
