When will wifi syncing be supported?
Hello there...
I usually don't post comments on forums because most of the time I can find a solution for what I'm searching for. Now, the main reason I'm moving from 1Password to Enpass is because I read somewhere on the forum that WiFi sync will be implemented on the next update. Today I downloaded the Beta just to find out that WiFi sync is not there...! I believe I'm not alone in this quest. Many users like me are very concerned about keeping their data in Cloud servers. Not to mention that I own a Mac and a Windows PC and it would be very easy to synchronize the data between the 2 computers (or more) over WiFi. Don't forget the iOS version of Enpass also. Otherwise, the WiFi feature would be useless...
Please, make it happen!  We're all counting on you guys.
Edited by Aleph
  • Replies 62
  • Views 123.3k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Dear Vikram This is crazy, did you consult with your bosses or read the previous posts in this thread? Right, you did not - Too bad, otherwise you would have known that Enpass canceled WiFi
Hey @Aleph
Thanks for writing in and sorry to have kept you waiting for so long.
The feature of the Wifi sync is already on our roadmap and will be available after the final release of Enpass 6.
Thanks for your patience.
On 10/11/2018 at 5:38 AM, Anshu kumar said:
Hey @Aleph
Thanks for your reply. But that should be implemented with the beta version so we can test it under different environments. Adding it at the end of the beta process is only calling for problems later.
Also, could we have only 1 thread for the beta testing program? I asked the same question in the main thread (https://discussion.enpass.io/index.php?/topic/4576-a-new-beta-update-of-enpass-6-is-now-available-for-linux-macos-and-windows/& dedicated to the latest version (220), but I find the answer here. Could you regroup those different threads dedicated to the beta version? TIA.
  • 2 months later...
Enpass 6 went live yesterday, but I found no reference to the WiFi sync.
Edit: since it shall be announced after the go live of 6, it is on schedule ;)
I’ll wait
Edited by FuN_KeY
  • 3 weeks later...
I went ahead and purchased the app thinking  this was going to be here.  Still waiting for that wifi sync that was promised as part of v. 6.  Any updates on it?
  • 1 month later...
How soon this month?  This is a major issue for me.  One of the primary reasons I chose Enpass was the ability to sync between my PC & phone.
I am also waiting for the WiFi Sync to finally use Enpass.
  • 4 weeks later...
I'll add my voice to the request for wifi sync. I'm increasingly concerned about syncing on the cloud.
Me too. Would be a very powerful feature for me.
Agree!  The ability to sync directly between devices without having to expose data to the cloud was the whole reason I originally switched to Enpass, and it used to do it automatically before the upgrade.  Anxiously awaiting, for sure!
  • 2 weeks later...
I am also waiting for the WiFi Sync to finally use Enpass, when are you planning to release this?
And i hope you want leave as waiting for to long,.....also dont forget the WiFi function in the portable version 6 please!!
Dont let us wait so long!!
  • 3 weeks later...
  • 4 weeks later...
I just updated to 6.1.0, and still NO wifi sync option that I can find.  I hope Enpass is not abandoning this!
  • 2 weeks later...
On 5/27/2019 at 5:17 AM, Rolly said:
Hi SailorTed
Sorry, but the WiFi function has been abandoned already in January 2019.
Most users do not understand the security impact of cloud synchronization and therefore did not request the WiFi synchronization. And for a few users, it was probably to complicated/expensive to implement.
Best regards,
Rolly
Boo sauce, I was about to purchase :/... This is not the password manager I was looking for, move along!
Hi , i just come from 1Password to Enpass.
After a long wait i just look if there the wlan sync would be build inside enpass.
But i, like others too,do not find that wlan Sync. I use Enpass on a Windows PC , an iPad and a iPhone.
For me it is a need , i do not want to sync to clouds. For me it is fine to sync it at my private wlan network between all my devices.
Without that Enpass feels not round . So i would like to ask friendly when the wlan Sync feature will come.
And when it comes would it be possible to sync between PC , iPad and iPhone ?
Thank your for your patience .
Greets Stephan
P.S. just read the message above , from J_Thomas and hope the will do it anyway
Edited by Lisino
  • 2 weeks later...
Hi, I purchased Enpass 6 because of the promises to implement wifi sync and I am still waiting for this to happen.
I do not like to sync passwords via any cloud (dropbox, apple, google or whatever), I have my database stored on my own Synology network drive and just want to sync the database to every device when connected to my local wifi. The 1 Password way of doing that, where a computer of your choice acts like a master and syncs the database from the network storage to all devices when you open 1 Password on them would also be fine.
Are you still planning on implementing this or can I stop looking at your forum every month to see if it finally arrived?
Thank you.
Can I suggest that those users who do not want to sync to an external cloud as a work around think of purchasing a Raspberry Pi and installing DietPi.  DietPi has a fairly easy setup for a bunch of default apps one of which is NextCloud, which would allow you to sync your data within your own network.  No I understand it is not as straight forward as WLAN Sync but it would be a solution.
  • 1 month later...
this Feature is also an essential one that is absolutely decisive for me.
Unless this will not implemented, i will not be able to consider switching
Edited by MicroJam
WiFi sync ABANDONDED? How can such an ESSENTIAL feature not be implemented FIRST?
And what‘s that nonsense about „to complicated“ or „risks involved with WLAN“? 1password has this feature, and it WORKS like a charm.
Unfortunately their „subscription/cloud“-pushing leads me to looking for other solutions. But not having a LOCAL sync (including the possibility via a shared network drive, to sync between various computers in the LAN) is a hard pass for me.
So Enpass was in my close circle of possible alternatives, but seems it already dropped out. Sorry.
Exactly my opinion. Great in a nutshell
+1 I won't be able to switch from 1password to Enpass because of that poor choice from the dev team
