May 24, 20215 yr Hi, I have 2 very annoying bugs that i hope you can fix. I been waiting a long time but so far they have not been fixed. 1) When i close enpass by pressing the X on the app or select close from taskbar it flashes and wants me to authenticate. This is very annoying. I show this in the clip i attach. Rename the file to IMG_1124 .mov (could not upload with .mov extention, this needs to be changed as well) 2) Using Macro on my Logitech G915 does not work in Enpass. And this is the only program that does not work with macro. I use my macro keys for simple email and numbers i use often but in Enpass it comes out as "vvvvvvvvvvvvvvvvvv". IT works perfectly fine on websites and evey program i use so this is Enpass bug! Please fix it. I use the latest version of windows 10 x64 + all patches + the latest Enpass v6.6.1 (804) Hope you can look into these issues. IMG_1124 .plist
May 25, 20215 yr Hey @vampyren Thanks for sharing the details. We'll look into this issue at our end and keep you posted on further developments.
May 29, 20215 yr Author On 5/25/2021 at 8:43 AM, Garima Singh said: Hey @vampyren Thanks for sharing the details. We'll look into this issue at our end and keep you posted on further developments. Thanks. The macro problem is really old though so please dont just dont say we look into it. Thanks!
