September 13, 20215 yr I discussed an issue here about a year ago that could be a rather serious security issue. The reply from Enpass back then was it could be duplicated and would be worked on. I am still seeing the behavior and was just wondering if it is still being worked? The original issue is here:
September 14, 20215 yr Hello @fhall! Thank you for the follow-up. Our concerned team is still working on fixing this issue and I have also marked this as a high priority. Your patience is highly appreciated.
August 1, 20224 yr Author We're heading on almost a year since your last reply (almost 2 years since I first reported it) and this is STILL an issue......any progress?
August 2, 20224 yr Hi @fhall, I appreciate you for being patient with us. The issue has been fixed and can be seen in future updates. In the meantime, we highly appreciate your patience and cooperation with us. SI-1448
