September 16, 20215 yr Hello, I encounter this problem: When I want to check the compromised PWs on my secondary vault, it works fine. But on my primary vault I get the message „no internet connection, try again”. At the same I use the internet, so the IS a connection. Where is the error? iMac 2019 on Mojave, latest Enpass version. Thx for hints. Update: After the 3rd attempt, it did work. Still strange why it needed 3 attempts ... Edited September 16, 20215 yr by Roobert Update
September 17, 20215 yr Hello @Roobert, Thank you for reporting the presence of this issue along with the system details. I have shared this with our concerned team for further investigation. Your patience is highly appreciated here.
September 17, 20215 yr Hello @Roobert, We have tested this issue on multiple systems with the latest versions of Enpass (App Store version 6.7.3 and Website version 6.7.2) and find it working as expected. For further investigation please help me with the following details: Share the number of items/attachments that you are using in the primary vault. Is the primary vault synced with a cloud account? Are you using the latest App Store version of Enpass: 6.7.3(888) or website version 6.7.2?
September 17, 20215 yr Author Hello Manish, I just let the check-PW routine run and again it works fine on both vaults. For your investigation of the previous failures, here's the data: - 335 items and 11 attachments in primary fault - No cloud-syncing involved, only WiFi - Enpass Appstore version 6.7.3 (888) Edited September 17, 20215 yr by Roobert
