August 30, 20215 yr Today I tried creating some passwords onto my enpass and noticed they were not appearing after clicking save.So I tried enabling cloud sync, hoping that it would work. After enabling cloud sync, my creating the passwords again and still did not show when I searched them up. After I closed the app and reopened, it said that my version of enpass was old. So, I checked and it is up to date(version 6.7.1). I tried uninstalling and redownloading and it is telling me my password is incorrect.I once again restarted the app and now it is saying my version of enpass is old!
September 1, 20215 yr Hi @Will.iam It seems that we have some issues with existing database file. We should restore a working version from backups first to restore your data. Please follow the below steps on your MAC: Quit Enpass(if Open) using Command+Q. Depending on the OS, Go to following Path in your System:/Users/$Username$/Library/Containers/Enpass/Data/Documents/ OR/Users/$Username$/Library/Containers/in.sinew.Enpass-Desktop/Data/Documents/Note - You might see multiple folders named Enpass here, please check in all such folders where you may find the Folder named Vaults. Also, Enable View hidden contents in Finder Here you will see a folder named Vault. Rename this folder. Say to “XYZ” Now launch Enpass Application. It will launch from Welcome Screen. Select Previous Backups Option Now Restore the latest Backup by providing your Master password. You should be able to restore Enpass from last backup state now Please let me know if you were able to access your data after following the above steps.
September 20, 20215 yr Hello have the same problem with Windows 10. Already update in Microsoft store and still not error exist Maybe you can help me
September 20, 20215 yr Hello Guys, I am using Windows 10 and installed the ENPASS via Microsoft store, My ENPASS suddenly require update so I update it and after I restart, It require again an update but upon checking the ENPASS in Microsoft store it is already updated. Can you help me please?
September 20, 20215 yr Hi @jecxnate, Welcome to the Enpass community. Thanks for sharing the screenshot of the issue. I have duly noted your feedback and it has been forwarded to the concerned team for further investigation. I'll let you know as soon as I have any updates regarding this.
September 22, 20215 yr Hey @jecxnate Just updating the steps here as a fix for the above concern with Windows. Quit Enpass(if Open) using CTRL+Q. Go to this location on your windows device (Data location).C:\Users\*username*\AppData\Local\Packages\SinewSoftwareSystems.EnpassPasswordManager_\LocalStateFor example: Here you will see a folder named Vaults. Rename this folder say to “XYZ”. Now launch Enpass Application. It will launch from Welcome Screen. Select the Previous Backups option. Now Restore the latest Backup by providing your Master Password. You should be able to restore Enpass from the last backup state now Cheers!!
March 19, 20224 yr On 9/1/2021 at 4:27 AM, Abhishek Dewan said: Hi @Will.iam It seems that we have some issues with existing database file. We should restore a working version from backups first to restore your data. Please follow the below steps on your MAC: Quit Enpass(if Open) using Command+Q. Depending on the OS, Go to following Path in your System:/Users/$Username$/Library/Containers/Enpass/Data/Documents/ OR/Users/$Username$/Library/Containers/in.sinew.Enpass-Desktop/Data/Documents/Note - You might see multiple folders named Enpass here, please check in all such folders where you may find the Folder named Vaults. Also, Enable View hidden contents in Finder Here you will see a folder named Vault. Rename this folder. Say to “XYZ” Now launch Enpass Application. It will launch from Welcome Screen. Select Previous Backups Option Now Restore the latest Backup by providing your Master password. You should be able to restore Enpass from last backup state now Please let me know if you were able to access your data after following the above steps. Under Win OS-10 ver. 21H2 (OS build 19044.1586), there is no such folder as 'Library'. Hidden folders/files is enabled
March 21, 20224 yr @thoronodor, Thank you for reaching out to us. On 3/19/2022 at 11:11 AM, thoronodor said: Under Win OS-10 ver. 21H2 (OS build 19044.1586), there is no such folder as 'Library'. Hidden folders/files is enabled This above path is for mac users. For windows the refer to below-mentioned path. On 9/22/2021 at 1:06 PM, Gulshan Dogra said: Just updating the steps here as a fix for the above concern with Windows. Quit Enpass(if Open) using CTRL+Q. Go to this location on your windows device (Data location).C:\Users\*username*\AppData\Local\Packages\SinewSoftwareSystems.EnpassPasswordManager_\LocalState
