October 17, 20215 yr Hi Forum, I've been using Enpass for quite a while now and I'm absolutely a fan of it. Recently I joined the website bitvavo. bitvavo is a crypto currency site, so 2FA is a must. The problem on this site is that the login form asks for username, password and TOTP in 1 form. Enpass is only filling username and password resulting in an error. If I first copy/paste the TOTP it works ok, but of course it would be nice not needing to do that. Thanks for looking into this!
October 18, 20215 yr Hello @Egregius, We have tested this on multiple machines including various Enpass versions and find it working as expected. So, I would suggest you to check if you have enabled the ‘Automatically copy and fill one-time code after autofill’ option from the Enpass browser settings. In case it is already enabled, try to disable and re-enable it and let me know if that works. Also, make sure you are using a latest Enpass version.
October 18, 20215 yr Author Hi, Thanks for testing! I already had that option enabled, so I disabled and enabled it again. Same results for me. When I select the site from the browser extension username and password are filled in and the form is submitted. That results in an error because the TOTP isn't filled in. Then the TOTP is filled in and the form is resubmitted after which a successful login occurs. But, then a mail arrives for the unsuccessful attempt and after a number of those you have to fill in a captcha check. I just tried this in several browsers: Chrome 94.0.4606.81 on Mac OS Monterey 12.0 Safari 15.0 on Mac OS Monterey 12.0 Chrome 94.0.4606.81 on Windows Server 2016 Tried with these Enpass versions: Enpass Beta 6.7.2 (885) on Mac, Enpass 6.6.0 (775) on Windows and Enpass 6.7.2 (887) on Windows.
November 17, 20214 yr Hello @Egregius, Sorry for the delay in response. I would like to share that your concern has been reproduced and our team is working on fixing it. Your patience is highly appreciated here. #SI-2375
November 17, 20214 yr Author Thanks for the update! Glad that the team could reproduce it, that't the first step in fixing something Please let me know when I can beta test it.
November 18, 20214 yr Hello @Egregius, Sure, recently we have released our latest 6.7.4 beta version. Please click here to download for Windows. Do let me know if that works.
November 18, 20214 yr Author Alltough my primary computer is an iMac I tested the 6.7.4 on Windows and the issue remains. I do like the new "default password manager" in Chrome on Windows! Is that also coming to Mac? Edited November 18, 20214 yr by Egregius
November 19, 20214 yr Author 21 hours ago, Egregius said: I do like the new "default password manager" in Chrome on Windows! Is that also coming to Mac? It does, I like it! Thanks for that great update!
November 25, 20214 yr Author I got it working now in Enpass 6.7.4 on Mac I duplicated my entry to have a backup of it. Than copy/pasted all required fields to the login page of Bitvavo and the webform got saved. After that I had to change the webform mappings and can now confirm that the login works as expected. Is there any way to add fields to the webform without needing to re-add the entry to Enpass? I have lot's of entries where I would like to add a "remember me" checkbox to the webform.
November 26, 20214 yr Hello @Egregius, We are glad that your concern has now been resolved. About the webform, it auto-captures the details and places them according to their field type. So currently, there are no options available to add a new field in the webform. For that, you have to add it manually from the Enpass app.
November 27, 20214 yr Author 17 hours ago, Manish Chokwal said: For that, you have to add it manually from the Enpass app. Sorry, don't understand that part. Where can I ad them? Or do you mean I have to manually re-add them completely? Is it possible to do it with a export/import?
