Chrome/Firefox/Edge Extension blocks dropdown on website
I can happily share with you that 'my' problem, about the "can't connect to the Enpass app" has been fixed, quite a while ago, with an update. Thanks!
  • Replies 51
  • Views 37k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Operations8
    Operations8
    I understand that it might be a difficult issue and when i reported it about 6 months ago i didn't expect an immediate solution. But after about 6 months there is still not a planning when the solutio
  • Well it should be flagged with the highest priority to be honest. Impacting the user experience to the point of preventing them to fill forms, select dropdowns is a serious matter. The fix propose
  • From my experience, it is not absolutely necessary to turn off the entire extension. It is enough to turn off the auto-fill pop-up in the extension settings. Then you at least have the possibility to
Posted Images
Hi @Cederd
We have addressed this issue in the previous updates. In case you are still facing this issue, I would recommend reinstalling the Enpass Extension once on your browsers and checking if the issue persists. If it does not resolve the problem, please share the URL of the web pages on which this issue is occurring, and I'll have this further investigated for you.
