November 23, 20215 yr Hi there, I am running into some form issues since the last update in all browsers that have the enpass extension activated. When trying to fill a form (here a form to add a subdomain in a server software called LiveConfig) I have one input and two dropdown fields. As soon as I set the focus on the input field I am no longer able to use the dropdowns. When clicking on them the focus immediately goes back to the input field. When the extension is deactivated everything is working as expected. This is also happening on Windows machines. Please provide a fix for this. Thanks!
November 24, 20215 yr Hi @nmcgn Welcome to the Enpass Forums. To assist you better with your query, please share the below details with me, and I'll get this checked for you - Version of the Enpass app, Extension and OS you are using. Link to the webform on which this issue is occurring. Screenshot depicting this issue would be immensely helpful.
November 24, 20215 yr Author Hi @Abhishek Dewan, thanks for your reply. 1. Enpass 6.7.4 (938), Extension in Chrome 95.0.4638.69, macOS 11.6 2. It requires login and contains sensitive data, so I can't provide this. 3. see 2. But you can try it in the online demo: https://www.liveconfig.com/en/demo/ . Login as Administrator and then, for example, try to create a new subdomain. Enter a name for the subdomain and then try to open one of the dropdown fields - they open for an instance and then close immediately...
November 25, 20215 yr I got the exact same issue while filling in the working hours in Harvest.io through Azure Devops. - The dropdowns refuse to activate when the "Show Inline Autofill Popup Menu" is enabled.
November 26, 20215 yr I have the same issue with the dropdown menu since the last update, in exact.com (also with login and sensitive data, so I cannot provide pictures). I have a Windows 10 PC and the problem occured in Chrome as well as in Edge. The problem was solved after I removed the Enpass extension from the browsers.
November 29, 20215 yr Hey @all We have reproduced this issue on our end, and our tech team is working on getting it resolved. A fix will be implemented soon in the upcoming versions of Enpass. Thank you all for reporting this issue, and we appreciate your patience in the meantime. #SI-2460
December 1, 20214 yr Same problem here. In Google Sheets, trying to share a sheet is not possible unless switching off the extension. (Microsoft Edge Version 96.0.1054.34 (Official build) (64-bit)) I think it is caused by the new popup below input fields. How can I switch that function off? The previous version was less intrusive and much easier to use.
December 1, 20214 yr 1 hour ago, JohnZ said: Same problem here. In Google Sheets, trying to share a sheet is not possible unless switching off the extension. (Microsoft Edge Version 96.0.1054.34 (Official build) (64-bit)) I think it is caused by the new popup below input fields. How can I switch that function off? The previous version was less intrusive and much easier to use. John, you can turn that troublesome feature off by reading this thread. Edited December 1, 20214 yr by Dypsis
December 1, 20214 yr Author 1 hour ago, Dypsis said: John, you can turn that troublesome feature off by reading this thread. @Dypsis Thank you! This saved me a lot of trouble with this annoying, new and seemingly not so well tested feature!
December 1, 20214 yr Hi I got the same issue as described in Mac forum and I hope it will be resolved also for windows, chrome? Attached a gif on how the drop down doesnt work, it works if I disable extension. (The form gets filled in the end because I tab myself and push arrow down). Windows 10 Enpass 6.7.4 (934) Chrome Version 96.0.4664.45 (Officiell version) (64 bitar) Edited December 1, 20214 yr by Cederd
December 1, 20214 yr Was my original post moved to a reply in this thread or did I post it wrongly? My issue is with Windows not Mac.
December 1, 20214 yr Hi @Cederd Thank you for sharing the details. This issue has been observed on all platforms, i.e Windows, MAC etc. I have also duly noted your comment and have shared it as feedback with the tech team. I will be sure to update this forum as soon as I receive any updates.
December 7, 20214 yr I am a very happy user of Enpass and always recommend it to everyone looking for a password manager, so thumbs up! But i am having a problem, i think since the latest Enpass update but i am not sure about that. I have been using the Enpass extension with this same website for more than a year so it did work before. On the website crm.realworks.nl the popups are being blocked / interfered with. (Dutch CRM website for realtors) What happens is, when i press the arrow which should show a dropdown box with a couple of options the dropdown allow appears for 0.5 sec and is empty. When i turn the Enpass extension off the problem is gone. Other browser doesn't solve the problem, the only thing that helps is turning the Enpass Extension off. I have added two pictures, on the first one you have to look close but you can see the outlining of the dropdown box. If needed i could translate the words shown on the pictures but i don't think that is really relevant. Edited December 7, 20214 yr by Operations8
December 8, 20214 yr On 11/29/2021 at 9:57 AM, Abhishek Dewan said: Hey @all We have reproduced this issue on our end, and our tech team is working on getting it resolved. A fix will be implemented soon in the upcoming versions of Enpass. Thank you all for reporting this issue, and we appreciate your patience in the meantime. #SI-2460 @Abhishek, is there a ballpark estimate when this new version will be ready?
December 29, 20214 yr Hi @Operations8 Our team is working on a fix that will be implemented soon in the upcoming Enpass version, but I will not be able to provide any ETA at the moment. Rest assured, I'm closely following this case and will share any news or update regarding a fix on this forum. As a workaround, for now, you can add the websites on which this issue is occurring to the block list on the Enpass Extension Settings page. Here's how you can do it - On your browser, go to its Settings → Extensions → Enpass Extension → Details. A new page will open. Please scroll down on that page and select “Extension Options“. On the Enpass Extension Settings page, scroll down to “ Inline Autofill Menu Blocklist“, copy the URL of the webpage where this issue is occurring and paste it in the “ Add URL “ field followed by an asterisk in the end. #SI-2460
December 29, 20214 yr 52 minutes ago, Abhishek Dewan said: Hi @Operations8 Our team is working on a fix that will be implemented soon in the upcoming Enpass version, but I will not be able to provide any ETA at the moment. Rest assured, I'm closely following this case and will share any news or update regarding a fix on this forum. As a workaround, for now, you can add the websites on which this issue is occurring to the block list on the Enpass Extension Settings page. Here's how you can do it - On your browser, go to its Settings → Extensions → Enpass Extension → Details. A new page will open. Please scroll down on that page and select “Extension Options“. On the Enpass Extension Settings page, scroll down to “ Inline Autofill Menu Blocklist“, copy the URL of the webpage where this issue is occurring and paste it in the “ Add URL “ field followed by an asterisk in the end. #SI-2460 Thanks for you answer. But as i posted before, i have to completely disable the Enpass Extension for the website to act normal. Anything else doesn't work.
January 10, 20224 yr Thanks Abhnishek for the workaround. I had to disable completly the Inline Autofill, cause the wildcard does not work very well. Looking forward for the fix.
January 10, 20224 yr Has this issue also something to do with the case that Enpass is blocking now completely e.g. my input of addresses via google chrome ? I have to fill out some forms and usually i always got the chrome proposals e.g. mail , name, phone, street, etc. Currently i am not getting this - in the chrome settings it says that Enpass is managing this. If i turn enpass off - google popup will work for e.g. addresses. If i turn Enpass on - its not working anymore
January 12, 20224 yr On 12/29/2021 at 9:47 AM, Abhishek Dewan said: As a workaround, for now, you can add the websites on which this issue is occurring to the block list on the Enpass Extension Settings page. Here's how you can do it - On your browser, go to its Settings → Extensions → Enpass Extension → Details. A new page will open. Please scroll down on that page and select “Extension Options“. On the Enpass Extension Settings page, scroll down to “ Inline Autofill Menu Blocklist“, copy the URL of the webpage where this issue is occurring and paste it in the “ Add URL “ field followed by an asterisk in the end. #SI-2460 Is there a description for the syntax of the URL? From the screenshot it looks like * is a wildcard. I'd like to block a domain and all subdomains - Should that be https://*.blockeddomain.com* ?
January 13, 20224 yr Hi @CarstenS Welcome to the Enpass Community! The Block-list is actually URL-specific and not domain-specific. However, If you wish to block certain domains or even sub domains, you can use wildcards by adding * before or after the domain. Please refer to the below examples - https://blockeddomain.com/* https://*.blockeddomain.com https://*.blockeddomain.com/* Hence, the URL field should accept most wild cards. However, if you face any issues while adding any particular domain, please let me know, and I’ll be happy to get it checked for you.
January 17, 20224 yr I am facing a peculiar issue where none of the input and drop down field are working in my page link https://eduhelphub.com/college-essay-writing-service. If anyone has similar issue or any solution please suggest me so that I can get rid of the situation, also note the issue has occured after last update in my browser. Edited January 17, 20224 yr by oli123
February 7, 20224 yr When using Windows Chrome or Edge with the Enpass extension I encounter difficulties trying to click into elements within an iframe. Please try: https://consultimator.com/customers/tl/testouter.html testouter.html contains: <iframe src="test.html" width="100%" height="600"></iframe> test.html contains: <style> :focus { background: pink; } </style> <input type="text" /><br> <textarea></textarea><br> <textarea></textarea><br> If you try to click from textarea to textarea, it will work. But it will not, once clicked into the input field. Deactivating the Enpass extension solves the problem, but that shouldn´t be the solution. Same problem exists with other elements, even input-elements like checkboxes, options etc.
February 15, 20224 yr Acumatica ERP is a fully web-based ERP, used in a browser. When Enpass is enabled, it makes certain fields nearly impossible to use. For instance, a combobox / dropdown won't expand or a textbox won't focus. Sometimes this is fixed by refreshing the page, but other times nothing helps. Disabling the extension for Chrome or Edge resolves the issues immediately.
