January 12, 20224 yr I'm running Enpass portable on my M1 mac. I keep getting this error when I open the app, "Unable to Run from Current Location. Please change portable execution location." Haven't been able to figure out if it's a problem with M1 or something I'm doing wrong. Thanks.
January 13, 20224 yr Hi @dalgza Welcome to the Enpass Forums! Enpass portable provides the assistance to carry all your passwords in the USB drive along with credit cards, bank accounts, ID cards, and other life-important credentials. Could you please confirm the location where you have set up your Enpass Portable File? I would also recommend checking out our user guide for Enpass portable and making sure that it is set up correctly. If the issue persists, then I will require some additional information. Please share the below details with me and I'll get it investigated for you - The version of the Enpass Portable app and OS you are using. A screenshot of the error occurring would be helpful. Are you facing this issue on any other device as well?
June 8, 20224 yr Hi, I have exactly the same problem. Unfortunately, abhishek-dewan's answer isn't really helpful. No matter where I start Enpass Portable (latest version) from, the said message always comes up. If there is already a defined error message like this, the support should know which requirements have to be met regarding the location. To abhishek-dewan's questions: 1. MacMini with Intel CPU with MacOS 10.15.7 2. Why? isn't the exact error message sufficient? 3. No, I only have a Mac. Best Regards Dorian
June 9, 20224 yr Hi @Dorian Welcome to the Enpass Community. I appreciate you sharing the details with me and have forwarded them to our dedicated team for testing purposes. As soon as they update me on this matter, I will be sure to notify you on this forum. Thanks for your patience in the meantime. #SI-2918
June 10, 20224 yr Hi @Dorian We were able to replicate this issue on our end. Our dedicated development is now working on fixing the bug and a patch addressing this issue will be released in the future versions of Enpass. We appreciate your patience in the meantime.
November 1, 20224 yr I have been using Enpass for years on a couple of Linux machines and on my wife's Windows device. Now I tried to use Enpass Portable. I downloaded v6.6.1 for Linux, unpacked it and copied the contents to a 2 GByte USB-stick with ext4 file system. When I try to start the executable, I get a notification, saying I need to change Enpass data location. There is an installed Version of Enpass on the device, but from what I read, it should work anyway. There is nothing I can do apart from hit Cancel. (see attached screenshot). The same thing happens on all other devices I have tried. I have seen mentions of this behavior from Mac users here and that was quite a while ago. Is there a solution by now? Edited November 2, 20224 yr by Ferdinand
December 19, 20223 yr Hi @trickzter Our dedicated team is already aware of this issue and they are working on a fix. Unfortunately, I will be unable to share any ETA right now but rest assured, I'll be sure to notify the users on this forum when a patch is released. Your patience in the meantime is appreciated.
December 19, 20223 yr For real? Since over a year? This is a bug which makes the app not usable. This is ridiculous.
December 21, 20223 yr On 12/19/2022 at 7:08 PM, Abhishek Dewan said: Hi @trickzter Our dedicated team is already aware of this issue and they are working on a fix. Unfortunately, I will be unable to share any ETA right now but rest assured, I'll be sure to notify the users on this forum when a patch is released. Your patience in the meantime is appreciated. this makes the enpass mac portable broken. How can it be taking so long to fix it ??
March 28, 20251 yr Hi is there any news on this matter? I have tried version 6.6.1 on Mac and it does not work as described here. On Windows the portable version works fine. It is very surprising that none of the developers seem to be available for the improvement.
February 23Feb 23 I found a workaround for Mac users that works for me. I copied the EnpassPortable app to a USB stick formatted as Mac OS extended. Previously, I double-clicked on EnpassPortable in Finder and got the error message “Unable to run app from current location...”. Here's how I was able to start EnpassPortable.I started a terminal and moved the working directory to the USB stick. In my case, “/Volumes/Volume,” so: cd /Volumes/Volume and then open EnpassPortable.app/. The above error message appeared when I started it for the first time. However, it no longer appears when I start it for the second time; instead, the Screenshot #2 screen appears.Here, I set the data location to /Volumes/Volume (my USB stick device), selected the Remember location checkbox, and confirmed with OK. And now the EnpassPortable app launches. To exit the app, please do not use the “red cross” but instead select Enpass -> Quit Enpass. This is the only way to exit the app properly. I hope this procedure works for other users as well. I "imported" a backup and noticed that restoring the vault took a very long time. I assume this is mainly due to the speed of the USB stick.
