February 20, 20224 yr When I choose "Use Website Icon", in some cases it finds an icon and displays it. I then save the entry and it defaults back to the generic icon. Is this a bug that is logged to be fixed? In order for the web icon to work I have to post the actual site URL in the Description field. If I do not do this I get the Error: "Invalid URL in Description field". This defeats the purpose of having a "Description" text field to describe the site. I already have a separate field with URL that tells me the URL information. These are just bugs that need to be addressed. Please let me know if you already have these logged and when you think you might be addressing them. System Info. Hardware: Macbook Pro 2020 M1 Chip with 16 GB RAM, OS: macOS Big Sur ver. 11.6, Enpass ver. 6.7.4 (938) Thanks!
February 21, 20224 yr Hello @Eddie, Welcome to the Enpass Community Forums. Thank you for reporting the presence of this issue. I have shared it all with the concerned team for further investigation. Your patience is greatly appreciated here. SI-2632
February 21, 20224 yr 19 hours ago, Eddie said: In order for the web icon to work I have to post the actual site URL in the Description field. If I do not do this I get the Error: "Invalid URL in Description field". Can you please share the url or screenshot with the error?
February 21, 20224 yr Author Sure. You will notice in these two examples (there are many more), the 1st picture does not have the URL in the Description field and so you get the error. The second picture has the URL in the Description field and so the Web Icon is downloaded without error. With the error, I cannot retrieve the Web Icon and just get the generic icon until I put the URL in the Description field.
February 22, 20224 yr Hello @Eddie, In order to assist you better, please help me with the following details: Please confirm if you have imported the data from another password manager or created the Description field manually. According to screenshots, the Type field for the Description is URL type. Please verify and change its field type URL to Text and let me know if it is still showing an error.
February 27, 20224 yr Author Answers: 1) I did not import from another program. I simply created it manually. 2) I changed the type to text and it now works! It no longer shows an error. I have no idea why I would have made a Description field a URL type. Lol I actually think, I somehow changed an item's description field to URL and then since I use duplicate when creating new items, the issue was propagated. Thanks for the help!
September 5, 20224 yr I am testing Enpass, and I did import from 1password. Many of the icons did not move over, and when I try to pick or generate an icon, the "icon pick list" does not scroll. I'm hoping there is a "Use Website Icon" somewhere, but I can't scroll to see if it is at the bottom of that list.
September 5, 20224 yr Hey @ImSeeker, Please try the following path to enable the option "Use Website Icons": Enpass settings -> Customize -> Use Website Icons.
September 5, 20224 yr 10 hours ago, Manish Chokwal said: Hey @ImSeeker, Please try the following path to enable the option "Use Website Icons": Enpass settings -> Customize -> Use Website Icons. That definitely helped. However, fyi, i still cannot scroll the "choose icon" area. Again, fyi. I am using a Mac, Monterey 12.5.1
September 13, 20224 yr Hey @ImSeeker, I appreciate your response. As you are testing Enpass, I would suggest you try our new desktop Beta v6.8.3 and share your feedback.
