August 3, 20233 yr Oh no, I'm sorry to hear that you're experiencing crashes with Enpass and your Google Drive vault. It can be frustrating when technology doesn't work as expected. Have you tried reaching out to Enpass support for assistance? They might be able to provide some insights or solutions to help resolve the issue. Wishing you a quick and smooth resolution so you can continue using Enpass hassle-free!
August 22, 20233 yr Hey Guys, Easy trick to temporary solve the issue is to use portable version instead of installed version. What you will lost is autofill popup window when you click in input box in browsers. Only via shortcut can be triggered autofill popup. Maybe for someone from enpass team, I found in event viewer: Faulting application name: Enpass.exe, version: 6.9.0.0, time stamp: 0x64b67d77 Faulting module name: ucrtbase.dll, version: 10.0.19041.789, time stamp: 0x82dc99a2 Exception code: 0xc0000409 Fault offset: 0x0009d132 Faulting process id: 0x689c Faulting application start time: 0x01d9d4d1a571fe7a Faulting application path: C:\Program Files (x86)\Enpass\Enpass.exe Faulting module path: C:\Windows\System32\ucrtbase.dll Report Id: 3a5635c4-ad8a-4331-a0df-b90e65cdf91c Faulting package full name: Faulting package-relative application ID:
