Enpass is crashing with Google Drive vault
Hey @Laceee,
Thank you for reporting this issue. When you reopen the app after the crash, does it shows a dialogue box about the crash report? If yes, please share it at support@enpass.io.
  • Replies 51
  • Views 27.8k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Migüelito
    Migüelito
    It works perfectly now.
  • Any new Feedback @Manish Chokwal As you can see there are several people affected by this issue. I also purchased the lifetime version, i am not from Russia (and i really don't think this is
  • Streiger
    Streiger
    Hi @Manish Chokwal, I sent the requested files to support except the log files because there aren't any created by the Enpass Manager. If we get a solution for this problem I will post it he
Posted Images
No, it doesn't. After (every) restart, Enpass asks for Master Password, opens up as usual and tries to sync again (green circle starts spinning). After a few seconds Enpass silently closes itself.
I was wondering, if You happen to have a build with extra test logging capabilities, I would give it a try, and could collect/provide some logs about this issue.
Edited by Laceee
Hi @all,
Today we have released our new beta version 6.8.3 for Windows OS which can be downloaded from here. Please try and let us know if you are still facing this issue.
Great news, I will try it, thanks!
One more idea related to this topic. Isn't it possible that the MediaTek MT7921 WiFi 6 Adapter Driver causes the crash? More and more new PCs are installed with this card, because Intel's card is unavailable on the market.
Unfortunately, the same issue with 6.8.3 beta version on my system.
Unfortunately I couldn't figure the main reason out, but I have managed to get Enpass working properly (at least on my laptop).
Originally windows setup doesn't have Mediatek wlan drivers, so you cannot connect to the internet at setup phase (my laptop doesn't have any ethernet card/port, and USB dongles are not recognized at this phase) and you are only able to create a local account to log in to Windows. I don't know if the problem is in connection with Microsoft local account or Windows drivers/updates, but it's a FACT that I have installed Windows Assessment and Deployment Kit, made a Windows ISO with Mediatek drivers added from Asus site, so I was able to connect to the internet, log in to Windows with my original Microsoft account and get some updates at setup phase. After this setup, everything is fine with Enpass.
Edited by Laceee
Hey @Laceee,
Thank you for sharing your feedback. I have forwarded it to the concerned team to look further. In the meantime, we would appreciate your patience and cooperation.
More than 3 months now with this issue...
One new "beta" version released, but the problem still is not solved after update^^
As soon as you try to connect GDrive, after granting of permissions the whole app crashes without further info. Every startup afterwards the app also crashes silently without any logs or errors. Turned off internet again, disconnected GDrive and Enpass works as intended without possibility to sync passwords via cloud.
Maybe we should start about talking about a refund?
  • 2 weeks later...
On 9/11/2022 at 7:17 AM, Dirk Cleiren said:
Udate: this morning i logged in in Enpass and the synchronisation works now? Weird
mine is also on 6.8.3 but still crashing.
Hi @Error404, @Dirk Cleiren and @Der_Chris_k,
I appreciate your responses. It would be a great help if you can share the crash reports. When you reopen the Enpass after the crash, it should show a dialogue box regarding the crash. Please add this forum post link and send us. Also, does this issue occur if Enpass is synced with other cloud services?
  • 3 weeks later...
Dear support,
Since a couple of weeks we have a problem with enpass with a combination of Google Drive
When enpass tries to synce enpass crashes with the following in the log
Info: [HTTP]  Using AUTO Proxy detection
Info: [HTTP]  Enabling VERIFY SSL PEER/HOST
Info: [HTTP]  CURLSSLOPT_NO_REVOKE
I have also send a crash report with a link to this post. We use Windows 10/11 machines with Different versions of enpass. Version 6.8.3 beta ( web version) Version 6.8.3. ( 1153) Windows store version.
I also send a crash report with a link to this forun post. If you need more info let me know.
Edited by RickHoekstra
  • Moderator changed the title to Enpass is crashing with Google Drive vault
  • 4 weeks later...
Hey @Manish Chokwal, the issue is still there. Enpass directly crashes after updating vault. There is no crash report and no dialogue box after reopening enpass. So this way we can not send you any crash reports. But do u still work on this? This issue exists now since 6 months !! :o
On 11/8/2022 at 11:47 AM, Manish Chokwal said:
Hi @all,
I appreciate you for being patient with us. I would like to share that a new Enpass v6.8.4 has been released. Kindly update and share feedback.
Bonjour,
I've updated to version 6.8.4, it still crashes right after starting and refreshing vault.
I try uninstall v6.8.4 and install the same version from Microsoft Market Place and I still have the same problem. Enpass is crashed when he try syncthing with GDrive, when I disconnect my internet Enpass work correctly.
On my phone with android it works correctly
  • 3 weeks later...
Hi, today I reinstalled windows 10 Pro, install Enpass, synchronize with google drive and... crash every time Enpass tries to synchronize. I install Enpass from Microsoft Store three times. Then found link to enpass intaller from your site - same problem. Before reintsalling windows it works really well. I enable journal, but nothing appended to it.
Hi, I don't know what is changed today, but Enpass doesn't crash after google drive synchronize!
That is what I have in journal (duplicated few times):
Today i received a message from the enpass support and they send me this instruction. Follow these steps and the synchronisation with GDrive will work fine again!
1- Enpass Settings>Advanced>Erase everything
2- Kill Enpass from Background
3- Rename Enpass folder again like Enpass_Crash or Enpass_Old and then remove the 6.8.5
4- Uninstall Enpass 6.8.5
Download the 6.7.4. here: https://dl.enpass.io/stable/windows/setup/6.7.4.933/Enpass-setup.exe
Finally! :D
  • 1 month later...
I'm having the same issue on a new Dell XPS with windows 11.
Tried installing the app both using the windows store and the download link here.
Below is the crash report:
Lognavn:       Application
Kilde:         Application Error
Dato:          03-02-2023 14:39:34
Hændelses-id:  1000
Opgavekategori:Crash-hændelser for program
Niveau:        Fejl
Nøgleord:
Beskrivelse:
Navn på program med fejl: Enpass.exe, version: 6.8.4.0, tidsstempel: 0x634fff1c
Navn på modul med fejl: ucrtbase.dll, version: 10.0.22621.1, tidsstempel: 0xbbf7fb0e
Undtagelseskode: 0xc0000409
Forskydning med fejl 0x0009c582
Proces-id 0x0x381C
Programmets starttidspunkt 0x0x1D937D4E94EFE63
Programsti: C:\Program Files (x86)\Enpass\Enpass.exe
Modulsti: C:\Windows\System32\ucrtbase.dll
Rapport-id: 5e417a4b-2791-4d3c-af4b-bb14f743b9ea
Fuldt navn på program med fejl:
  • 3 weeks later...
Finally! :D
Thank you for posting the solution here. Today I tried again to get enpass to work on Windows. Always the same picture: Enpass opens, shows that I am entitled to an upgrade and closes the window. End.
The solution to delete everything and install version 6.74 helped.
Just do not understand why ENPASS team does not publish the solution here ??????
  • 2 weeks later...
I have the same problem.
Wanted to Download the 6.7.4 - but it's no more available!
This issue exists since 9 Months ...
Enpass Team: Please help us!!
Edited by Hombianer
  • 3 weeks later...
Just experienced the same thing on windows 11 and with Enpass 6.8.5.
It works fine with vaults which are not related to google drive, but as soon as I add a vault with google drive the app crashes and I get no warnings or error messages.
This seems like a problem which should be adressed fast? Any ETA on when you will ship a working version?
  • 2 months later...
It's now 2023 , Enpass 6.8.6 is still crashing after adding google drive vault under windows 10.
Are you guys going to fix it finally ?
In order to get it back working somehow I neeed to uninstall it and use different vault, which for now stopped me from buying any subscription. This is unaccaptable to have a bug like this for such a long time.
If you guys won't be able to fix it soon I will have to move to another password manager.
Edited by crashev
