June 27, 20224 yr 1. go to https://netbank.takarekbank.hu 2. choose VICA 3. username cannot be filled This is not the usual user/pass combo here, but it's the same username as the other option would use. Is there a way to configure it manually somehow?
June 28, 20224 yr Hi @Idoki, I appreciate your efforts in reporting the presence of this issue. I would like to share that some banking/financial apps/websites do not allow third-party autofill. Additionally, you can try to save this website's details via a webform and then try autofill. For more details on webforms, please visit the user manual. Furthermore, in order to assist you better, please help me with the following details: Share the details of the Enpass version and OS information. Did you install Enpass from a store or our official website?
June 29, 20224 yr Author Thanks for your input. * Current macOS with newest patches * Enpass 6.8.2 from Mac App Store (this data cannot be copied easily/at all, can it be improved?) Saving the web form doesn't seem to work. I don't have that option above Quit Enpass. I'm using the safari extension, the documentations seems to use something else.
June 30, 20224 yr Hi @Idoki, Thank you for the response. I have shared all the details with the concerned team for further investigation. In the meantime, your patience is highly appreciated here. SI-2959
July 21, 20224 yr Hi @Idoki, Thank you for being patient with us. Our team was able to reproduce this issue and working on fixing it. Its fix can be seen in future updates. In the meantime, your patience is highly appreciated here.
