August 27, 20224 yr Since a few months I experience massiv problems with WebDAV and the support is actively ignoring my requests. I wrote about the following problem in two support tickets (ECS-30210 & ECS-30252). Both times I received acknowledgments from the Jira ticket system, and both tickets were actively deleted a few hours later without further notice! When I click the "View request" link and login to the support system, I'm told that the issue can not be found and doesn't exist. Maybe they are going to delete this topic as well, but I have to try. Now, the problem: Almost every other week sync stops working and I'm told that my password is wrong and I need to enter the new one. However, sometimes it just displays a numeric error code without further explaination. My password didn't change, and so far the only way to get it working again, was to restore the ~/Library/Containerse.sinew.Enpass-Desktop folder from a Time Machine backup. That always worked but is nothing I wanted to do forever, so I decided to disconnect all devices, remove the WebDAV contents and start again. But now, when I try to set up the connection again, I'm instantly told by Enpass that it could not connect to the specified WebDAV folder and that I should check my username and passwort, which are definitely correct! This only happens on MacOS. I also had iOS, Linux and Windows devices connected to the same WebDAV server and never encountered the problem on any of them. I tentatively identified that it has something to do with the WebDAV path containing a space, but this wasn't a problem when I initially set it up in March of this year. However, if I shorten the path up to the directory above the problematic part, it does connect, then instantly fails with error 906403, because that directory is read-only. I can do nothing about this suboptimal situation, because this is just how OpenXchange URLs look like. The full scheme is ""https://server.example/servlet/webdav.infostore/Userstore/Firstname Lastname/". I also tried encoding the space by typing %20 or +, but that didn't work either. In case of %20 the error code is 906409. This needs to be fixed and soon! PS: While the errors only happened on MacOS, re-setup seems impossible on any device now. At least the Linux version is able to write some kind of log file, but all I got was this: Info: [HTTP] Enabling VERIFY SSL PEER/HOST Info: [HTTP] Using AUTO Proxy detection Error: [configTeamVaultsSync] 120 ERROR in enabling sync for primary : local : true Info: [HTTP] Enabling VERIFY SSL PEER/HOST Info: [HTTP] Using AUTO Proxy detection Info: [HTTP] Enabling VERIFY SSL PEER/HOST Info: [HTTP] Using AUTO Proxy detection Info: [HTTP] Enabling VERIFY SSL PEER/HOST Info: [HTTP] Using AUTO Proxy detection Info: [HTTP] Enabling VERIFY SSL PEER/HOST Info: [HTTP] Using AUTO Proxy detection Info: [HTTP] Enabling VERIFY SSL PEER/HOST Info: [HTTP] Using AUTO Proxy detection Info: [HTTP] Enabling VERIFY SSL PEER/HOST Info: [HTTP] Using AUTO Proxy detection Not very informative... Definitely not what a good debug log should look like. No information about the HTTP requests that were sent and what they resulted in. Edited August 27, 20224 yr by Bachsau
August 29, 20224 yr Hi @Bachsau, Thank you for reaching out to us. Please accept our apologies for any inconvenience caused. Your feedback has been noted and I have also received your email support request. You have received a response there from me. Please check ECS-31081 to track the progress of this issue.
August 29, 20224 yr Author I just answered your followup questions via email. However, I really would like to know why my previous tickets were just deleted.
September 13, 20224 yr Same issue here. "Almost every other week sync stops working and I'm told that my password is wrong and I need to enter the new one. " please fix this ASAP
September 13, 20224 yr Hi @chris132, Thank you for reaching out to us. I would like to share that this issue has been reproduced by our backend team and they are working on its fix. The patch addressing this issue will be released in the future updates of Enpass. In the meantime your patience and support is highly appreciated.
September 26, 20224 yr @chris132, Unfortunately, as for now we do not have any update regarding the ETA of upcoming build addressing this issue. I will update you on this as soon as I receive any updates from the team.
September 29, 20224 yr This is a joke right? I cant sync with nextcloud or Icloud. Both have the same issue. So I am stuck now with wifi sync and this is not working on my corporate wifi. Do you even see how much this impacts your product? Going back to keepass. byby
