October 10, 20224 yr Hello Enpass Team, This issue has been there for a long time. I'm thankful that you fixed the issue where inline autofill wasn't working on browsers like chrome and brave. But for vivaldi, the accessibility autofill doesn't work at all and also the issue where the username/email field isn't filled
October 10, 20224 yr Author As you can see from the above photos, when I focus on the username field, there is no inline autofill or accessibility but when I focus on the password field, the inline works but when I use it, only the password is autofilled. I brought this up earlier and a member of the team told me to turn off the inline and only use the accessibility autofill which actually worked. So using only the accessibility autofill fixes this. But I really like the inline much better and want to keep using that. Please look into this.
October 10, 20224 yr Author I'm using: Enpass v6.8.3.726 Vivaldi latest version Android 12 on One UI 4 I recently updated to Android 12 and this existed even on Android 11
October 11, 20224 yr Hey @Nyagaka254, I appreciate your efforts in reporting this issue. I have shared it with the concerned team to investigate it further. In the meantime, your patience is highly appreciated here. SI-3133
October 6, 20233 yr Just came to bump this issue... Enpass in Vivaldi — desktop and mobile — seems to be much less reliable than with other browsers.
October 9, 20233 yr Hi @ValZho We will gladly get this checked for you you but to do so, we will require some additional information in this matter - The version of the Enpass app, OS and browser you are using. The URL of the webpages on which you are facing this concern. A short video showing the issue would be helpful. (You can share the video with us at support@enpas.io and mention this forum).
