October 11, 20224 yr I have been noticing for a few days that logging into Microsoft websites (Outlook.com, Office.com, etc.) is no longer possible. The Enpass Extension no longer performs a login on these sites. When trying to start the extension via the icon, nothing happens anymore. I also noticed that the extension completely loses the connection to the Enpass app after opening the Microsoft pages and subsequently no longer works on other websites. Only a restart of the Enpass app solves the problem. If a Microsoft website is opened again, the extension loses the connection again. Enpass Extension 6.8.0 (Safari + Firefox) Enpass 6.8.3 (AppStore Version) MacOS 12.6 on M1 MacBook Pro 14"
October 12, 20224 yr Hey @datarepos, I appreciate your efforts in reporting the presence of this issue. I have shared it with the concerned team for further investigation. In the meantime, your patience is highly appreciated here. SI-3136
December 16, 20223 yr Author I played a little with the settings of the add-on for testing. In doing so, I noticed that the problem no longer occurs when I disable the "Show popup menu to auto-fill" setting. All other settings have no influence on the problem, also the sync settings of the vault have no influence. Maybe this will help the Enpass team in their analysis. Regards datarepos
