November 1, 20224 yr Hello, I switched from 1Password to Enpass and now I have a problem with opening attachments on Mac. I have in various cards for example a PDF file (no image). When I want to open that on the Mac, I have to save it to disk first, and then I can open it only. In 1Password I could open it at least with the app "Preview" (press the space bar). Is it possible that here Enpass is rebuilt that I can open data directly? Thanks a lot Translated with www.DeepL.com/Translator (free version)
November 2, 20224 yr Hi @mike5186 At the moment, only .img and .txt formats can be directly opened on Enpass Desktop. For all the other attached documents, you will need to save them first in order to open it. However, I have duly noted your comments for further consideration. #SI-2554
