November 7, 20224 yr •When I copy something from Enpass (Mac desktop) and try to paste it to an iOS device via Universal Clipboard, the field is blank. It acts like it pasted something, but nothing is visible. On the Mac if I paste the Enpass text into a note and then copy the text from there, I can paste into an iOS device. •From Enpass on iOS to the Mac copy/paste works fine. •In the past I was able to copy from any instance of Enpass (iOS or Mac) and paste into Apple TV via Universal Clipboard. This no longer is working. This functionality is part of Apple's Continuity system. Wondering if anyone else has seen this behavior? Enpass 6.8.3 (1150) MacOS 12.6 on a 2017 Macbook Pro.
November 8, 20224 yr Hi @Welshdog It seems that you are using an older version of Enpass on your Mac. Could you please update your Enpass app to the latest version 6.8.4 and check if the problem persists? If you are still facing this issue, kindly share the version of the Enpass app and OS you are using on your iOS device as well and I'll have this further investigated for you.
November 10, 20224 yr Hello, I have the same problem and use the latest versions. MacOS Ventura Version 13.01 (iMac M1 Chip), Enpass 6.8.4 iPadOS 16.1.1 , Enpass 6.8.5
November 11, 20224 yr Hi @heik1887 Thank you for sharing the details. I have forwarded this concern to our dedicated team for testing and will get back to you soon with an update. Your patience in the meantime is appreciated. #SI-3176
November 15, 20224 yr Hi @heik1887 Our team was able to reproduce the bug on our end, due to which this issue is occurring, and our development team is working on resolving it. Moreover, soon a patch addressing this issue will be released. Thank you for your cooperation and support in the meantime.
June 23, 20251 yr Author If there is no solution to this Apple Mac Enpass Handoff problem please let us know. My workaround is to paste the clipboard from Mac Enpass into a Note, then copy the data from there to my iPhone. Not ideal, but it works.
