April 9, 20206 yr Hello I would like to sync vaults using pCloud. But, when 2FA is enabled on pCloud, it is not possible to use the WebDAV protocol for synchronisation. It would be great to have proper pCloud integration in Enpass for a more secure and convenient way to synchronise vaults. I'm aware this feature has already been requested here and here. Since the first request was in 2017, I would just like to register more support for this. Many thanks
April 10, 20206 yr Hi @Sebastian S Welcome to the forum! I would like to share that you can sync Enpass with pCloud using WebDAV. To do so, please refer to this link. Also, we really appreciate you for exploring the app and giving time in finding this valuable suggestion. The suggestion has been noted and forwarded to the development team for further consideration. Thanks for weighing in. Thanks.
June 16, 20206 yr +1 while WebDAV is not an option with pCloud as WEBDAV is disabled if you use two factor authentication in pCloud. Saftey first, a full integration of pCloud would be nice.
June 17, 20206 yr Hey @Zero-One Welcome to the forum! We really appreciate you for exploring the app and giving time in finding this valuable suggestion. The suggestion has been noted and forwarded to the development team for further consideration. Thanks for the suggestion!
June 19, 20206 yr +1 Since I have numerous problems while syncing with iCloud I changed to pCloud syncing and would like to be able to use 2FA also.
January 8, 20215 yr +1 because WEBDAV is not available anymore if the user choice the European-Union as the target of the data storage for the PCloud-Account!
January 8, 20215 yr 3 hours ago, Zero-One said: +1 because WEBDAV is not available anymore if the user choice the European-Union as the target of the data storage for the PCloud-Account! webdav is still available. the url is https://ewebdav.pcloud.com
January 8, 20215 yr ...thanks but still not possible with 2FA enabled, which even Enpass recommend to use in their new version ;-)
October 14, 20215 yr Hi there, I like the product, however adding pCloud integration would be really helpful, please DO NOT suggest WebDav as it won't work on some services when 2FA is enabled including pCloud and disabling 2FA is not the best idea Edited October 18, 20215 yr by toomaj
December 22, 20214 yr + It will be very helpfull to use pcloud directly not over webdav. Using 2FA also with pcloud and Enpass is really important.
May 22, 20224 yr The pcloud.com webdav access is not working really good. It sometimes produces errors or stops syncing. The only way is to disconnect and reconnect the webdav (in my case the europe link ewebdav). I had this same issue with Cryptomator. But after they supported pcloud.com api everything worked fine. It would also be possible to use 2fa which I cannot at the moment, as webdav does not support that. So can you please check if you could extend the cloud services and add pcloud.com? Would appreciate that API Link: https://docs.pcloud.com/
November 30, 20223 yr Hello, I would like to ask you to add pCloud. https://www.pcloud.com/eu Thanks in advance.
December 23, 20223 yr Hi @Fadi Enpass is always grateful for our active users and your efforts in notifying us of this feature. I forwarded this request to our developers and would like to inform you that they have investigated its feasibility & unfortunately, this request cannot be taken into consideration. Your support and effort are greatly appreciated.
January 2, 20233 yr Hi @Abhishek Dewan, is there any explanation of why you won't support pCloud with 2FA? As some of the former writers do, I also would prefer to use 2FA for syncing with my main-cloud instead of using another provider only for this task. It is much easier to accept a decission when you know why. Else it is another straw on the camels back.
March 11, 20233 yr I am a pCloud user as well and i would like to have the native integration as was done for the other providers. As far as I read, Enpass is not gonna go to implement this integration. I think the the userbase of pCloud is becoming greater than before. Does the might change the development decisions?
March 17, 20233 yr +1. pCloud will be a very nice-to-have feature. I would like to switch from any popular mass-advertised platforms to something focused on security
May 8, 20233 yr Hi, I can only confirm the wish of many users here: It will be very helpfull to use pcloud directly not over webdav. Using 2FA also with pcloud and Enpass is really important. Can you guys confirm any progress on this?
October 1, 20233 yr +1 WebDav is not a good solution. Please add support for pCloud so that I can use my most trusted cloud service that are actually keeping my data secure.
