Bug - sort by modified
Sorting items by modification date at least on Android is incorrect. First and second item might show up correct but than the months gets scrambled in some other order. Since the last modified item always shows on top is often what's needed I haven't bothered.
Latest Android app, 5 vaults (although sorting gets wrong with only one vault shown).
430 items in total
Hi @Ivarson
Thank you for sharing the requested details.
I have forwarded this concern to our dedicated team and will get back to you soon with an update. We appreciate your patience in the interim.
#SI-3266
Hi @Ivarson
We have reproduced the bug on our end due to which this issue is occurring. Our dedicated team is now working on resolving it and soon a patch addressing this issue will be released. Thank you for your patience in the interim.
  • 2 weeks later...
On 2/8/2023 at 11:59 AM, Abhishek Dewan said:
Hi @Ivarson
If you already recreated this issue, this should be known by you, but I'll mention it anyway:
The "sort by created" actually sorts item by modification date. While this is still a bug, I can at least achieve what I want.
  • 2 years later...
Unfortunately, nothing has happened since February 2023. The sorting option in the Android app still does not work correct.
Pixel 8 pro / Android 15 / Enpass V6.11.9.1081
